Grille replacement
Anyone know where I could get a M20 speaker grille? I am the lucky guy that the candle leak all over the fron t of the speaker
. It is all cleaned off, but in ceratin light I can see a shine that I assume is from the left over oils in the cloth. Of course, I am open to cleaning technigues also. The steamer got all the wax off, but the oil is proving a little more difficult. Thanks!
Post edited by nate552 on
nate552 wrote:Anyone know where I could get a M20 speaker grille? I am the lucky guy that the candle leak all over the fron t of the speaker
Send an email to customer service, explain the situation and tell them you are a ClubPolk member. Chances are that Ken will send you one for free if he pitties you :P)KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
