Dual Subs
austina007
austina007 Posts: 1
I'm an HT newbie so this might be a silly rookie question but here goes. Can I wire another sub into my system by spliting the signal at the receiver's sub out using a Y-connector? Receiver is an HK635, sub is PSW505. If so does it have to be special connector to carry the LFE signal? Also, stacked or separate corners? Any advice is appreciated.
Post edited by austina007 on
  • michael_w
    michael_w Posts: 2,813
    edited January 2006
    Yep a y-adapter is just dandy. Some say stacked is the way to go but if you have stereo pre-outs you could try doing stereo subs (one near the left main speaker, other near the other), but that is probably only a good idea if you have two of the same sub.
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    Yep, you got the idea. Just pick up a sub Y-cable and do it up...
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • bassaholic
    bassaholic Posts: 315
    edited January 2006
    I have 2 stacked PWW650's....and I love it. So (2) 505 I love it. SVS eat your heart out. Actually never heard an SVS
    Pioneer SC-37
    RTiA9-fronts
    CSiA6-center
    RT55i-surrounds
    SVS PB13 Ultra & PSW650
    Monster Power 3250 amp
    Monster Power 2250 amp
    Monster Power HDP-2500 surge pro.
    Denon 3805,CS400i,RT25i's & FX500i's sitting in the basement collecting dust
