Bass-ically Confused
OK, This may make your head hurt. But here it goessss.
I have a PSW350 sub I think has been over worked. It pops when in DTS mode, sometimes other low levels. I have a DEF TEC supercube 1 behind the counter at the pawn shop I got for 2 bills. Top plate scratched up. Cant sell before refinishing. Don't know how to refinish. I can't find a replacement 10 cheap enough to make anything off the 350.
I WOULD LIKE TO STAY ALL POLK !!!
Do I use the 350 amp to push :eek: shakers under the couch? And keep the :eek: DEF TEC?
Wait forever to run across a cheap 10 for the 350. Sell it and the DEF TECH to finance a PSW????
The catch is. If I hookup the DEF TEC, put the 350 in the closet that is the way it all will stay. NO SALE...
TOY INVENTORY
TOSHIBA 65HM167 (DLP)
ONKYO TX-SR603X (AVR)
Logitech Harmony 880 (REMOTE)
PureAV PF60 (POWER)
polkaudio CS400i (CENTER)
polkaudio RT1000i (MAINS)
polkaudio FX300i (SURROUNDS)
polkaudio RT25i (REARS)
polkaudio PSW350 (SUB)
DefTech SuperCube I (SUB)
Post edited by gadgetdad on
Welcome to CP!
Where are you in OK.? The 350 isn't a real deep digging sub, and I would think the DT puts it to shame. Any sub amp will drive bass shakers, some of them require 25-50 watts, unless you get into Buttkicker or Clark Synthesis lines that are much more $$$.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
Get rid of both of them and buy a better sub (Hsu, Outlaw or SVS, not Polk).HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Hey Dennis,
Thanks for the response. I'm in Meeker, OK.. Yes, the 350 doesn't go to deep. I guess it wouldn't be to bad to add the DT to the equipment list. As far as the Clark and Buttkickers, I have a seven piece sectional. I need to spread it around a little. I figure I can series four shakers off the 350 amp without any problem. Anyway, keep in thouch.TOY INVENTORY
TOSHIBA 65HM167 (DLP)ONKYO TX-SR603X (AVR)Logitech Harmony 880 (REMOTE)PureAV PF60 (POWER)polkaudio CS400i (CENTER)polkaudio RT1000i (MAINS)polkaudio FX300i (SURROUNDS)polkaudio RT25i (REARS)polkaudio PSW350 (SUB)DefTech SuperCube I (SUB) -
Forget about the shakers. Just a buy (or build) a decent sub and you won't need them.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
Thanks for the input. I've been looking at SVS. For the moment I will have to get the DT, figure out how to refinish it for sale. I should turn a pretty good profit, helping to finance my upgrade.TOY INVENTORY
