50' Elite Purchased - Now Need Help With In Wall Speakers TC265i/LC65i
I am seriously considered the TC265i for the front in wall speakers and because of stud constraints either the TC65i or LC65i for the center channel. A couple of questions please.
Can I mix the TCs 8 ohms with the LCs 4 ohms or does this present a problem?
Is there a needed distance from the plasma to the speaker so not to interfere with the display? In my situation the side speakers would only be about 4 inches from the TV but would be in wall so the magnets would actually be further.
Are in wall enclosures a good idea and if so does Polk offer them?
Any help would greatly be appreciated.
Thanks,
Jeff
Thanks,
Jeff
Post edited by jdber94 on
I just in stalled TC265is around my pooltable and bar. Go with the enclosures. You can get them for $100 each from brand-electronics.com.
If possible pick a line a go all TC (RTi) or LC (LSi).
Stay about a foot away from the screen. They should not interfere with your TV.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3 -
Thanks, I'll go with all TC's.
Can the TC 265i as a center be installed vertically?
I hope I can get a foot away from the TV, if not is their a barrier available?
Do you have a sub suggestion for this system?
Many thanks,
Jeff -
These links are useful
http://www.polkaudio.com/downloads/LCi_Cutsheet.pdf
http://www.brand-electronics.com/products/?product=38192TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
