So I need to extend my RCA cables...
rnp614
I have a Dell 2405WFP that I'm using as a monitor for my XBOX360. The problem is that I have the component in going to the monitor but the stereo sound cord isnt long enough to make it to my AE preamp. Is there a way for me to extend this cable?
They sell extention cables...
(Has a female connector on one end and a male connector on the other)
They also have couplers, which is two female connectors for you to plug two male connectors together.
Ratshack sells either.
its cheaper to buy the female/male cables though than the couplers.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I ended up just getting the female female couplers and using some extra interconnects...but it was funny. When I said I wanted female ends (for a Y cable for my sub) the RatShack lady gave me a really offended look until I explained what I meant
