Back surround speaker placement ?
da5176
da5176 Posts: 42
Hey guys, I need some suggestions for back surround sound speaker placement. I have a 7.1 speaker system. The room is 19.5' X 12.5' X 7.5'. The side surrounds are going about 3.5' from the back wall facing toward one another. They will be about 3.5' behind the main listening position. Any more forward to the sides of the main spot can't be done due to a 4' wide window. The question is this, the back wall is wide open for back surround speakers. The distance is 7' from the back wall to the main spot. How far apart should the back surround speakers be? Should they be at the same height as the side surrounds? I'm re-arranging furniture, flipping from one end to the other. Wife wanted a change, and think I can get better surround speaker locations than before. We have more room this way so I need to make things work. Any help would be appreciated, Thanks:)
NOT MUCH, BUT IT'S ALL MINE!
SONY 60" SXRD (HDTV)
Explorer 8300HD (HD-DVR CABLE BOX)
Toshiba SD-3750 (DVD PLAYER)
Onkyo TX-SR702 (RECEIVER)
Polk Monitor 60 (FRONTS)
Polk CS2 (CENTER)
Polk Monitor 30 (SIDE SURROUNDS)
Polk Monitor 30 (REAR SURROUNDS)
Mirage Omni S-12 (SUBWOOFER)
Tripplite HT 1000UPS (POWER PROTECTION)
Omnimount (CENTER CHANNEL SHELF)
B-Tech BT34 (SURROUND SPEAKER MOUNTS)
Post edited by da5176 on
  • danger boy
    danger boy Posts: 15,722
    edited January 2006
    I don't have much experience with rear surrounds myself.. but the couple of friends of mine who do have them.. seem to place them to close to each other..
    I'd say, and this is only a guesstimate... place them around 4 to 6 feet apart.... most people i've seen have them about 18" apart.. that always seemed to close together in my limited experience.
    As for the height.. yes, you want them the same height as your side surrounds.. which is about 3 to 3.5 feet above your ears while seated.
    good luck.. sounds like a fun project. pics please once you have them up and running.
    PolkFest 2012, who's going>?
  • cnjvh
    cnjvh Posts: 253
    edited January 2006
    here is Dolby's recommended layout - tweak to taste (click the PL IIx button to get the 7.1 layout:
    http://www.dolby.com/consumer/home_entertainment/roomlayout.html
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    try placing the rear surrounds 1/2 the width of the side surrounds and 2/3 the width of the front L&R pair as measured with the center speaker.
    a good example would be this: (forgive if my math is off)
    Front- 6feet apart
    Center
    Sides- 8feet apart
    Rear- 4feet apart
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
