center speaker
higgins79
i noticed alot of people placing their center channels right ontop of their tvs.
i got a pretty big tv (50 inch lcd hitachi ) is putting a big center ontop of that going to bad. vibration etc. it would be more convienent than having to build a shelf on the wall for the speaker?
TV ................Sony kdl52xbr4
Reciever ........Denon AVR 988
Amp -............Monster MPA 2250
Bluray............Sony PS3 (80gig)
Hddvd............xbox 360 Hddvd
Power centers.Monster 3600II & 2600II & 1600 x2
Voltage..........Monster AVS 2000
Fronts ...........polk Rti12s
Center ..........polk Csi5
Rears.............polk Fxi5s
Sub ..............Infinity PS12
cables............Monster / DIY
Video games...XBOX 360 / Wii
Post edited by higgins79 on
If you have space under, the Polk csi3 and cs1 can be turned upside down and placed under. This would be ideal if you had space on a shelf below.
got a csi5 to big to fit under tv. people seem to have them ontop of their tvs in the system showcase but i just wanted to make sure it was ok for the tv before i set it all up.TV ................Sony kdl52xbr4
Video games...XBOX 360 / Wii -
I have a CSi5 which I have sitting on top of my rear projection TV. I haven't noticed any problems with it being there. Just be sure to install the rubber feet on the bootom of the speaker where it will come in contact with the TV.
Plus the "kickstand" on the back of the CSi5 works well to keep it level.
Bruce -
as long as its stable where you put it, by using the rubber feet or kickstand if needed. it should be fine.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Audiophonics AB310 preamp, DIY1200as2 Icepower Amp, Wiim pro streamer and Topping E70 Velvet DAC, California Audio Labs DX1 CD player, Polk LSi9 with modified crossovers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
This is what I purchased to put my LSiC on top of my 50" Hitachi LCD projection screen. It works great.
thanks just went and got one!TV ................Sony kdl52xbr4
Just make sure the top of you TV is strong enough to hold it up. I had mine up there for awhile (almost a year), and started noticing a sag on the top of the TV (the speaker is pretty heavy). It's on a shelf now (I was planning on putting it on one from the get go, just took a while to get to it). I don't think it does any harm, but over a bunch of years it may.Denon AVR-3803
RTi-70 Fronts
FXi-30 Surrounds
RTi-38 Back Surrounds
Csi-40 Center
PSW350 Sub
Panasonic PT-56WXF95 HDTVSamsung un60JS8000 SUHD
Denon DVD-2910
Xbox, Gamecube, PS2, PS3, PS4, xbox360, Wii, WiiU, n64
