Putting resistors on SL2000's
candyliquor35m
Has anyone played around with putting resistors on the sl2000's? I'm thinking about trying it. What value/values should I try besides the 100% ones that some of you will recommend? Thanks.
Post edited by candyliquor35m on
Are you upgrading the crossover, or trying to tame the output?Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Tame the output to sound more like a SL3000.
You aren't going to be able to tame the 'spike' centered at 12K cycles, without affecting the overall response. Your cheapest, and best alternative, if you absolutley refuse to buy new tweeters, is to put a graphic equalizer inline (parametric preferred), and reduce the line signal around that frequency (12Khz) by 3-5db.
If you want to try a resistor across the leads, start around ~18ohm - should give around a 3db drop.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
