Old Monitor 7 --- New Question
Eiderlon
Eiderlon Posts: 23
edited January 2006 in Vintage Speakers
Has anyone had any success adding an active 10" sub to the M7? If so, what Xover and cabinet mods did you make (if any)?
Lexicon Toshiba Crown EAW
Post edited by Eiderlon on
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited January 2006
    No, and only one post is needed on the subject.
    Polk engineered the speaker, and it sounds fine as is. You need more bass, add a separate subwoofer, or buy bigger speakers.
    Cheers,
    Russ
  • dkg999
    dkg999 Posts: 5,647
    edited January 2006
    +1 on Russman's comment. No more frankenpolks needed!
    DKG999
  • Eiderlon
    Eiderlon Posts: 23
    edited January 2006
    I hear you --- But..... Your reply IMplies that there ARE Frank-N-Polks out there doesn't it? Perhaps you can direct me to Frank's Forum, eh?
  • dudeinaroom
    dudeinaroom Posts: 3,609
    edited January 2006
    heres the link for frankenpolks it's www.yourdumd.com
  • michael_w
    michael_w Posts: 2,813
    edited January 2006
    Where do you live? If you're close I'll give ya twenty bucks for em just to save them from the brutal torture they're about to incur.
