Butler Audio 5-Channel Tube Amp
Early B.
Early B. Posts: 7,900
edited January 2006 in Electronics
Anyone ever get a chance to hear one of these?
http://www.butleraudio.com/tdb5150.php
It was reviewed in the latest edition of Home Theater Magazine. They make a 2-channel version, too.
"God grooves with tubes."
Post edited by Early B. on
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2006
    Specs wrote:
    • Rated Power (all channels driven):
    5 x 150 Watts RMS per channel @ 8 ohms
    5 x 225 Watts RMS per channel @ 4 ohms
    • Freq response: 20Hz to 20kHz (+/- 0.5dB)
    Power Bandwidth: -3dB, 50kHz
    • THD: <0.10% @ 8 Ohms, <0.15% @ 4 Ohms
    • S/N Ratio: Better than 110dB (A-Wtd)
    • Slew Rate: 15v/µsec
    • Input Sensitivity: 1.5V for 150 Watts into 8 Ohms
    • Input Impedance: 47k Ohms
    • Idling Consumption: Approx. 120 Watts
    (Approx. 1A @ 120VAC or 0.5A @ 230VAC)
    • AC Consumption (Nominal power):
    1200 Watts @ 8 Ohms - 10A (120VAC), 5A (230VAC)
    1800 Watts @ 4 Ohms - 15A (120VAC), 8A (230VAC)
    • Dimensions: 17"W x 16"D x 8.5"H w/feet (7"H w/o feet)
    • Weight: 48 Lbs. (19.2Kgs.)
    Wow. Now that's some amazing specs for a piece of tube gear. I think I'd be real interested in hearing opinions on this technology. Is this a relatively new piece? Is it still considered tube or is it a type of hybrid design? 150 watts...into 5 channels...with fr of 20Hz to 20kHz...with less than .10% THD...and a sn ratio of greater than 110....:eek::eek::eek: Wow.
    • Load Independent; Will drive any speaker
    Interesting.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • audiobliss
    edited January 2006
    Professional celebrity users include Pink Floyd, Billy Gibbons (ZZ Top), Eric Clapton, Elton John, Eric Johnson and hundreds more.
    Wow. That's quite a list of customers.
    Why use Vacuum Tubes in a computerized world? Ask any Music Industry professional. Tubes SOUND BETTER!
    See, cfrizz? Tubes sound better! Now go get some! :p
    I think these amplifiers would be ideal for seeing what tubes would do for the LSi series. Would be interesting to find out. Are there other high-end tube amps out there offering 250watts into an 8ohm load? If so, I haven't seen 'em.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • audiobliss
    edited January 2006
    Hand selected/matched 6SL7GT Twin Triode tubes
    (One per channel)
    Anybody heard of that type of tube before? I personally haven't, but then I've only heard of about 3 or 4 different types, so...:p
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • BlueMDPicker
    BlueMDPicker Posts: 7,569
    edited January 2006
    I believe it's a 5691 variant.
  • amulford
    amulford Posts: 5,020
    edited January 2006
    It's a hybrid. It's using a nifty design, though. I wouldn't waste it on HT. SACD, maybe.
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2006
    The first I've seen of this, & yes quite a star list of customers.
    However, I reserve judgement until someone from here gets one & reports back!
    BTW, how much does it cost & how much does it weigh?
    The only thing from stopping me from getting a 5 channel amp right now, is that they are just too heavy for me to manange!
    I really admire Darla (Wingnut) for managing all of her heavy equipment by herself!
  • Early B.
    edited January 2006
    Cost is $3,295 and it weighs 48 lbs, so it's fairly lightweight. You can handle it, Cathy. There's a brand new one on audiogon for $2,000:
    http://cls.audiogon.com/cgi-bin/cls.pl?ampsmult&1142791175
    Somebody pleeeaaase buy it and report back.
  • HBombToo
    HBombToo Posts: 5,256
    edited January 2006
    I was pretty amazed when I read about it in HT Mag this month... Looks like a real nice piece and I'll bet it sounds great.
    HBomb
    ***WAREMTAE***
