HK 635 heat
Ace944gs
Ace944gs Posts: 110
edited January 2006 in Electronics
Hey everyone,
Quick question...how hot should a HK 635 be after about I've watched 1 DVD? I recently touched the top of it, and it was surprisingly hot, almost concerning. Not sure if this is normal or what...Got 5.1 Cambridge audio SoundCubes speakers/sub hooked up to it.
I have a bad setup right now in terms of AV furniture, so there is NOT enough ventilation for anything down there I know, but just wanted to ask around to see if the situation was 'dire'!
Thanks!
Post edited by Ace944gs on
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    Hi welcome to the forums Ace. Yeah, change your setup to provide adequate ventilation asap. Use AT LEAST 3 inches- preferably 4. Check the ohm rating on your Cambridge speakers. If they're under 8ohm, then that's another problem.
    Ventilation and Ohm.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • MSkeezer
    MSkeezer Posts: 1,183
    edited January 2006
    HK's normally run kind of hot. Like aa said, make sure it has plenty of room to breathe.
