SDA 1.2 tweeter protection
autoconsortium
autoconsortium Posts: 64
edited January 2006 in Vintage Speakers
I have noticed some of you discussing a small electronic protection unit used in the Polk SDA 1.2's, and I believe I may be having an issue with these. I have the regular 1.2's and not the TL. I did uprade the tweeters, recently, with the dome ones from Nakamichi, I, of course, did all 8. Now that I have the newer tweeters, do I still need this level of protection? The reason I ask, when I am giving these speakers some heavy wattage, the tweeters will go dead. Almost every time it is both channels doing it, and only once has only one speaker had the tweeters go dead. I turn volume down, and they kick back on. There is zero distortion or amp clipping going on when the tweeter protector diaphrams(?) kick in. Should I get new ones, or are they working properly by protecting these expensive tweeters.
Alex Cagann
Polk SDA SRS
Lexicon DC-1 preamp
(2) Lexicon 501 monoblock amps
Parasound CD Transport 1000
Parasound DAC1000
Nakamichi Dragon
Nakamichi RX505
Post edited by autoconsortium on
  • thehaens@cox.net
    thehaens@cox.net Posts: 1,012
    edited January 2006
    You need some new polyswitches, you can get them from Polk CS, if you send then an email they will probably send em' your way for free..
    Scott
    PS I had the same prob. w/ mine, got the new polys and away went the problem..
    F1nut Posts: 51,776
    edited January 2006
    Nakamichi???
  • george daniel
    george daniel Posts: 12,096
    edited January 2006
    F1nut wrote:
    Nakamichi???
    Nakamichi ? I replaced the polys when I did my cap upgrade and have not "tripped "them yet,ask nicely and polk will send you some, mine were free. Polk C S is numbah 1. :)
  • Tour2ma
    Tour2ma Posts: 10,177
    edited January 2006
    +2
    Nakamichi???
    More later,
    Tour...
    Vox Copuli
  • autoconsortium
    edited January 2006
    Sorry...I didn't mean to put Nakamichi in there...however, I am as big a fan of Nakamichi as I am of Polk Audio. I will get the new poly-switcheroo's and put them in. They are getting worse every day...tonight my treble is kicking off far before they are turned up loud.
    Alex Cagann
    Polk SDA SRS
    Lexicon DC-1 preamp
    Parasound DAC1000
    Nakamichi Dragon
    Nakamichi RX505
