THX Select 2 vs Ultra 2 - Receiver selection
kmartin971
I am considering the Yamaha V2600 with is a THX select 2 receiver.
Anyone know the difference betweenn THX Select, Select 2, Ultra, and Ultra 2?
The THX website does not offer anything? http://www.thx.com/mod/products/hometheater.html
Only difference they state is Select is for rooms upto 2000 cubic feet and Ultra is for rooms that are approx. 3000 cubic feet.
http://www.audioholics.com/FAQs/THXHomeTheaterSelectvsUltra2.html
My room dimersions are 15x22x8=2640 cubic feet. Sweet Spot will be approximately 10 feet from the screen.
Give that I have already invested in the LSi series, what should do?
TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Side Rear (2) = LSiFX
Rear (2) = LSiFX
JBL S120P II
Sony Upconverting DVD Player
XBox
XBox 360 (Wireless connection live and media center enabled)
PS3
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3
Post edited by kmartin971 on
Your room is only 330 sq. ft (15 ft x 22 ft).
I would worry less about THX certification and more about researching receiver reviews and specs. I was at Best Buy this weekend and saw a $450 Pioneer receiver that was "THX Certified", but was rated at 120 W/ch @ 1khz @ THD <.9% for the surround channels. This is definately not the receiver I would want running my home theater. Take a look at Dennon, H/K, higher end yamaha's and maybe Onkyo. I don't even know if H/K (Harmon Kardon) has a THX certified receiver, but they make a hell of a good receiver regardless. I'm not overly knowledgable about receiver quality, but I would ask questions from the people on this forum relating more to receiver performance and less about THX. I think you will end up happier.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
Signal Cable Analog II IC's
Signal Ultra Bi-Wire Speaker Cables -
I agree with a_mattison. Look for the best specs on the receiver. Better yet, go with seperates and dont look back.
THX is a marketing ploy created by George Lucas. Most high end audio companies do not even participate in THX. Of all the gear I had, only one was THX certified, it was the only one to break on me.
Venom -
I have read the same thing about THX.
THX certified only means it is well built and george approved of it. (For a fee of course)
I believe all my equipment is as good as, or better than, what george puts his THX cert. on.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Don't focus on THX, focus on getting a receiver that has all the features you want & sounds good with pre-outs so that you can add separate amplification.
Better yet since you have already spent good money on LSI's go with separates altogether & be done with it.Marantz AV-7705 PrePro, Classé 5 channel 200wpc Amp, Oppo 103 BluRay, Rotel RCD-1072 CDP, Sony XBR-49X800E TV, Polk S60 Main Speakers, Polk ES30 Center Channel, Polk S15 Surround Speakers SVS SB12-NSD x2 -
Separates. Splurge and get 'em.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
Last I checked SQ footage is measured as
Length x width x height
Not to be rude but please do not post if you can't do basic math!
HK does not offer a good 7.1 receiver. I have done lots of research.TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Cubic, cubic, what's a cubic?
Cubics are for squares.
Abbr. sq. Expressed in units measuring area: square feet.
Abbr. c or cu. Having a volume equal to a cube whose edge is of a stated length: a cubic foot.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
kmartin971 wrote:Last I checked SQ footage is measured as
Length x width x height is volume or cubic ft. not sq. ft. a_mattison is right. You are wrong and rude for jumping down his throat with that comment. I think you owe him an apology. He tried to help you.
Venom -
My bad - the original post could have been phrased correctly!TV = WS65611
Pre-Amp Onkyo 830
Amp Aragon 2007
Panamax 5510
Towers = LSi25s
Center = LSiC
Rear (2) = LSiFX
JBL S120P II
XBox
PS3 -
Thanks for backing me up on the square footage. My B.S. in Physics helped me with that one.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
I have a PhD in my office, it only cost me $50.
Venom -
Dr. Venomclan,
I'm in NPD and Marketing now, so $50 is about all my physics degree is worth now unless somebody wants to get into some kind of math argument. No work in Physics.HT
RTi70 mains
CSi30 center
RTi28 Rears
Velodyne CHT-12
H/K AVR-247
ADCOM GFA-7000
Samsung PN58B860
Playstation 3
2-Channel
Polk Audio LSi15's
Rotel RCD-1072
Nakamichi CA-5 Pre
ADCOM GFA-555
I have been in the Marketing field for many years. How much do you think my English degree is worth. If it is tied to my career, then a lot I guess.
A degree just gets you in the door to many different places, its what you do with it that counts. I know many millionaires with degrees from colleges you never heard of and do not exist anymore.
Venom
