Plasma decision made...
I-SIG
I-SIG Posts: 2,243
edited February 2006 in Electronics
...and the winner is going to be the Panasonic 42" HDTV (TH42PX50U). None of this EDTV BS for me. :) Also, I don't play video games and don't leave movies paused for more than a few minutes so burn-in and all that crap meaningless to me.
With that said, I still have a few questions.
Since planning on running (at this point) Comcast cable and DVD player as my only two sources, would I be better served by the professional model that doesn't have the HD tuner built in assuming I can find a significant price difference?
Assuming I did get the professional model, how much are the DVI or HDMI cards?
Is there some model that I can't find on Panasonic's website that comes with a wall mount kit instead of a table stand?
Finally, will the EMF from my unshielded SRS's affect the performace of a plasma TV?
I think that's all for now.
Thank y'all,
Wes
Link: http://polkarmy.com/forums
Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
Post edited by I-SIG on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2006
    Sweet looking at the same model, but a little loss with your other questions so I'll standby also......
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • bvette94
    bvette94 Posts: 356
    edited January 2006
    I have narrowed it down to the panasonic also but i am looking at the 50 hdtv. imo panasonic has the best pic quality. i suggest a built in tuner.i dont know how the unsheilded speakers will affect it.i am curious about this my self.
  • Mike Reeter
    Mike Reeter Posts: 4,315
    edited January 2006
    I-SIG,Please let us know your thoughts when it's all said and done...getting ready to up-grade monitors,and this model is on my short list...Thanks,Mike
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2006
    I still would love to have an LCD tv but since we will be moving into a house toward the end of this year (either renting or buying) Im going to wait til then and buy something like a 34" CRT instead.
    The only reason I could justify spending $2000 more on a LCD would be because its so much lighter and I wouldnt have to drag it up these apartment stairs!
  • SKsolutions
    SKsolutions Posts: 1,820
    edited January 2006
    My 2 cents:
    If you don't plan on using an antenna to get your HD, then you don't need a built-in tuner. Absolutely NOT needed.
    I have a Panasonic Professional model (no tuner, speakers), and it's got the newest 8th Generation panel, a sexy as hell black picture frame look, and a PC hookup.
    All this for around 2400 shipped for the HD. Better picture than the consumer model, for less money. I resarched for quite some time and this was dollar for dollar the best I found. Panasonic TH-42PHD8UK
    Before you buy check it out.
    -Ignorance is strength -
  • SKsolutions
    edited January 2006
    Here's a pic. The thumb says 65", but they all look like this 37"-65"
    The same panel as the Panny $5K SvS series for less than the cheap looking silver consumer model at CC. I'm very glad I looked before buying. 2100. shipped.
  • madmax
    madmax Posts: 12,434
    edited January 2006
    Hey Isig, check out Sams Club. Our local one has a 50" HDTV plasma for $1999. Initial glimpses look like any other plasma. Worth checking out. Made by Akai but whatever...
    madmax
    Vinyl, the final frontier...
  • Toxis
    Toxis Posts: 5,116
    edited January 2006
    FYI, Panasonic plasmas went on a national back order til May. The company is doing a lot of restructuring, so they say. What they did was fire every single person except the CEO and are making everyone reapply for their jobs. Even before all this, panasonics have been in short supply for a while. Good luck finding one and if you do, I personally wouldn't buy it... I've seen a few of them come back with bad pixels out of the box or get burn in very easily. Just heads up...
  • SKsolutions
    edited January 2006
    The mean failure rate of Panasonic is lower than anything in it's pricerange, and the warranty is honored without hassle. If you don't buy anything, nothing will ever be wrong with it.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    Well, I don't have a nice stand to keep all my gear on. At this point, I figure why spend big $$ on a stand that can support a big tube and a 70lbs Parasound when I could spend most of that $$ on a plasma and wall-mount it. :)
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    My 2 cents:
    That's exactly the one I'm interested in on the pro level screens.
    My thinking is very much along your lines. If I have digital cable and a dvd player, why do I need a tuner? and why do I need speaks with a pair of SRS's and a SVS sitting around. :)
    Who has it for $2400 shipped? Those BeyondPlasma guys off ePay?
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    madmax
    I'll certainly give it a look see. Thanks, max.
    I imagine there's probably about 2-3 folks actually making the screens, say Panny and someone else. The rest are just re-badge's, etc.
    Wes
  • SKsolutions
    edited January 2006
    Sorry, it's actually cheaper. 2100. shipped, my mistake. I got mine at www.Plasmahouse.com, and they were effecient. If they are backordered, shop around. Try www.streetprices.com. Do be aware. With some dealer: if you are not buying a stand (purchase it at Nerds.com), or 150. HDMI cables, they tend to try to put off shipping for like 2-3 weeks. Some places just don't have it in stock.
    PlasmaNext has em for 2100. shipped as of today.
    Try pricing:
    streetprices.com
    pricescan.com
    cnet.com (pricing for models)
    Good luck, the TV is wicked pissah.
    Sean
  • SKsolutions
    edited January 2006
    Wes
    Most major players make their own or spec order them. The panel driver is just as important, and that's where you see some manufacturers skimping.
  • fireshoes
    fireshoes Posts: 3,167
    edited January 2006
    madmax
    Avoid AKAI plasmas like the plaque man. We sell a 42" monitor at work and probably half have had issues. Several DOA's.
  • madmax
    edited January 2006
    I would give one a chance only from Sams Club because of their liberal returns. A warranty sounds like it would be in order too. :D
    In any case what I-sig is looking at is better, just wanted to throw it out there because it is the first one I've seen even close to that price range.
    madmax
  • hoosier21
    hoosier21 Posts: 4,413
    edited January 2006
    decision made????? are you sure?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    haha, those things suck.
    My favorite HD plasma right now is a Philips model, it has better shadow detail than units costing much more.
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    Yeah, I'm pretty sure. I spoke with a seller with a Phoenix office. I can pick it up in PHX, but I still have to pay shipping to get it to Phoenix. :( If I'm gonna pay for shipping, might as well get delivered a lot closer.
    Wes
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2006
    My favorite plasma, with the exeption of price, would have to Fujitsu. I just haven't seen others that compare to them for most models. Seeing how they hold most of the major patents for the technology, I would hope they were better. The Panasonic(at retail) is almost half(even at my cost) of the Fujitsu(P42XTA51US).
    Tschüss
    Zach
  • bpadget
    bpadget Posts: 65
    edited January 2006
    http://www.electronics-depot.com
    Check these guys out. They did right by me even during the Christmas rush.
    I hung it with a peerless mount from mounts and more.
  • shawn474
    shawn474 Posts: 3,052
    edited January 2006
    I guess I don't understand the benefit of having a built-in tuner. I rent my tuner for HD service from comcast at $5 a month. The price difference is pretty inflated for built-in vs. external and with all of the technology, is it possible that these will need upgrading or not be able to convert future signals? I have a Panasonic rear projection that with the high def. feed looks as good as any plasma, lcd, or dlp. I am completely happy with the purchase, the quality and customer service are top of the line. I don't think I'd ever buy another brand after this experience.
    Shawn
    AVR: Marantz SR-5011
    Center Channel: Polk LsiM706c
    Front: Polk LsiM703
    Rear: LSI fx
    Subwoofer: SVS 20-39pci
    DVD Player: Sony PS4
  • punk-roc
    punk-roc Posts: 1,150
    edited January 2006
    I-SIG, i purchased that exact TV about 3-4 months ago and i've loved it ever since. I wouldnt hesitate purchasing it, i bought my locally since Onecall.com is based in Spokane, so that was convenient.
    Jason
    2-Channel - So far...
    Pre: Dodd ELP
    DAC: W4S-Dac2
    Source(s): Computer and Denon 2910
    Amp: Parasound HCA-1200II
    Speakers: LSi9s - Vr3 Fortress Mod
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    Shawn,
    That's one reason why I want to get the rpofessional model over the commercial. If some new format or connection method comes out, I know I can swap out a card on the back of the plasma and be ready to rock 'n roll.
    As for the tuner, I'm in your boat. Why do I need it if I'm gonna pipe in a Comcast HD signal and my over-the-air reception sucks **** on my side of town?
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    Jason
    Thanks, Jason. The same guy that SKSolutions used has a place up in Phoenix, so unless a local guy here in Tucson can come through with the commercial Pioneer unit, I'm gonna drive to Phoenix and get one there. I'm gonna check onecall out to sure.
    Wes
  • I-SIG
    I-SIG Posts: 2,243
    edited January 2006
    Well, I placed my order. He's supposed to have a new shipment of the 42" pro level HD Panny's in early February. I'll be ready for the SuperBowl if I'm lucky. I know I'll be ready for the Daytona 500! (Not to mention DVD's!)
    Wes
  • steveinaz
    steveinaz Posts: 19,538
    edited January 2006
    ALRIGHT BIG Money! Cool beans, bust out that Sara Maclaklan....
  • punk-roc
    edited January 2006
    Good Luck, hopefully everything works out for you. Let me know if you need more info
    Jason
    Pre: Dodd ELP
    DAC: W4S-Dac2
  • SKsolutions
    edited January 2006
    I have viewed Fujitsu's panels and they are stunning, and I dig their laptops too. Expect to pay double or treble for the 10% to 15% difference though. For me, it doesn't rate as high as the Panny pro-line for value per dollar.
  • SKsolutions
    edited January 2006
    UMM, you require that 'tuna' whether or not you have one built in. The 'box' you rent is to decode the HD comcast broadcast.
    There is absolutely NO reason to have a built in 'tuna' if you don't intend on stringing up an antenna on your roof. So, with DVD and Cable like most of us: NO 'TUNA' required.
