The ideal setup? Quest for flat?
ttrentt
Is the true quest for speakers, a flat response? Maybe I am nuts...
I have a 30 band stereo (60 band total) Alesis M-EQ230 which is supposed to be a very decent EQ with the very wide band.
I spent the last hour using test tones and a radio shack meter to get my JBL L26s within about +/- 3DB @ 80 DB from 40 HZ to 15000 HZ.
The only really odd sections are at 71 DB, there is a 5 DB positive spike, and at 142.5 a 11 DB negative spike (I assume this to be a limitation in the ported design).
Switching the EQ in and out and doing an A/B test is very interesting. I can't decide which sounds better. They both sound decent -- but I am used to A, not B.
I have only made + or - 4 DB adjustments on the EQ -- and this has the speakers pretty flat. I think vocals and cymbals seem a little crisper. Low end also seems a little more defined.
Anybody do crap like this? Is the final judgement the ears, or the meter? Ears will get used to a different style sound. Do they need to get used to what the meter says is flat? SHould I trust that damn thing so much?
Trent
Trent
Post edited by ttrentt on
The final judge is always your ears. We buy this stuff to enjoy music, right? Use what sounds best to you...Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Yep. ALWAYS go with what sounds best to you.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
