Speaker baffles?
SportsFan
I'm curious what others think about speaker baffles (i.e. - XTC speaker baffles, etc.). Do they actually HELP "enhance" the bass (as I've heard some people mention), or are they a complete waste of money?
I'm thinking about adding some baffles for my rear deck 6X9 db690s, and I'm curious if others have had good experiences with them and think that they would be worth it. They're cheap, so cost isn't an issue...but realistically, can one expect slight (not significant, just slight) improvement in bass response and overall sound quality?
'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
Sirius Starmate 4 Satellite Radio
Beltronics Vector 995 Radar Detector
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
Post edited by SportsFan on
Its not about enhancing the bass really as all frequencies can benefit.
Say you mount a speaker to a thin, metal door panel. Now when you crank up the volume the speaker will vibrate and in turn so will the door panel. These vibrations can and usually will be transmitted to the speaker and can severly color and/or distort its output.
Using a good baffle, like say a 1/2" piece of plywood covered in Dynamat, you can be assured that no vibrations will be transmitted to the speaekers cone and what youll be hearing is only what the speaker puts out and not what the door panel "adds" to it.polkaudio sound quality competitor since 2005
I like to use the XTC baffles in the door to protect from carwash drenchings in older cars with lesser designed seals. Other than that benefit, I don't notice any sound difference. I wouldn't waste the $ or effort on rear decks.HT Optoma HD25 LV on 80" DIY Screen, Anthem MRX 300 Receiver, Pioneer Elite BDP 51FD Polk CS350LS, Polk SDA1C, Polk FX300, Polk RT55, Dual EBS Adire Shiva 320watt tuned to 17hz, ICs-DIY Twisted Prs, Speaker-Raymond Cable
OK, I think Im talking about something different.
If youre talking about the semi enclosures that go around the magnet to keep water and such off of them then no, they wont enhance anything. Theyll help keep the elements off of them but theyre not airtight so they wont act as an enclosure.
If youre talking about a mounting baffle like a piece of MDF with the speaker mounted to it and then it mounted to the door, then my above statement applies.polkaudio sound quality competitor since 2005
I think what he is talking about is the foam baffle. I don't think they will really enhance the bass response much. But they will act as a shield against water and weather in general. Thats about all I see there good for is protecting your speakers.
The foam baffles also work well for protecting rear deck speakers from subwoofer pressure. I have blown several 6 1/2's and 6x9's on rear decks from sub pressure. I have also seen the surrounds ripped completely from it, and it will keep that from happening.Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
i agree... the baffles work great to keep the elements away from a door speaker (although i'm far too lazy to use them unless i actually see a problem such as water inside the door panel while doing an install).
they are also great for 'insulating' a deck speaker from subs... did it in the ex gf's car, worked out nice.
for any other use, i'd say they're worthless... but at 6 bucks a pair, they're cheap rain/pressure protection.The Artist formerly known as PoweredByDodge -
Yep, you guys are right....I was thinking of the "foam" type baffles for the rear deck 6 X 9s. I've heard some people say that they help "enhance the bass"....and my trunk is rather large, so if having baffles would better help push the sound through the speakers grills into the car as opposed to losing sound in a spacious trunk, I was thinking of adding some. Not so much for protection (rear deck of a '98 Accord), but to improve sound quality throughout the car.
Thanks for the replies......'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
Beltronics Vector 995 Radar Detector -
I saw some hard PLASTIC speaker baffles advertised.....don't know if they work better (or worse) than the foam, but I thought I'd throw that out there, in case anyone has used either and could comment on them. I heard someone say (somewhere) that he used baffles surrounded by Dynamat and he seemed to like the results. Anyway, since I won't be adding a sub, anything that is a cheap way to improve sound quality is something that I'd consider.'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
you could get an infinity basslink for just under 200 on ebay. Or throw a bazooka tube in there. If you definitely aren't going to go the sub route... The baffles will decrease the bass response because they will see it as a very small enclosure. The only way to get better bass response out of them while leaving them on the rear deck would be to seal off the trunk compartment completely from the rest of the car. And stiffen the rear deck itself to all hell. Really though, you will be dissapointed with the baffles if you are looking for more bass. I think if you would just take Macleod's idea of making baffles out of plywood covered in dynamat you will notice a world of difference in bass response.Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
Youre never going to get very good bass response out of standard speakers. Theyre just not capable of producing it.
If you want good bass youre going to have to break down and buy a sub. It doesnt have to be anything huge or complex, a humble DB 8" in a sealed enclosure with 200 watts would make a world of difference.polkaudio sound quality competitor since 2005
PoweredByDodge wrote:buy a sub
I simply want a good sounding system.....I'm not trying to win any competitions or "impress" anyone because they can hear me coming from down the block....'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
MacLeod wrote:Youre never going to get very good bass response out of standard speakers. Theyre just not capable of producing it.
If you want good bass youre going to have to break down and buy a sub. It doesnt have to be anything huge or complex, a humble DB 8" in a sealed enclosure with 200 watts would make a world of difference.'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
Dont associate using a sub with vibrating the windows out of the car next to you. Thats not what its about at all. Thats like saying I dont need more horsepower in my car cause Im never gonna drive in NASCAR. For best SQ you have to have a sub because it takes a sub to reproduce freqencies from 80 and down. A regular speaker just cant pull that off.
A single 8 or even 10" sub properly powered and dialed into the system would do nothing more than fill out your sound and drastically improve your overall SQ.polkaudio sound quality competitor since 2005
MacLeod wrote:For best SQ you have to have a sub because it takes a sub to reproduce freqencies from 80 and down. A regular speaker just cant pull that off.
A single 8 or even 10" sub properly powered and dialed into the system would do nothing more than fill out your sound and drastically improve your overall SQ.'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
I totally agree with what MacLeod said. It will be very hard to get well balanced sound without a subwoofer. I myself have only a 10" sub, and I am happy with it thus far. I do not try to impress anyone but myself
. The sound system is for me
. You can actually get 10" subs that go into enclosures that are .66 or less. My friend has an 8" sub that he put into a .35 cubic foot enclosure. I think it sounds very nice. Has a 2001 Eclipse (the ones with a trunk). Also Class D amps are getting pretty small now, especially one that would be capable of pushing an 8" sub.
If you still do not want a sub, you may have to get a receiver with some signal processing built in to help out. My unit has this. It is from SRS Labs and they call it TruBass. It kind of makes your ears think they are hearing lower frequencies from your speakers, and it's done without overdriving them.
Here is a quote from Eclipse's web site & the link to it:
http://www.eclipse-web.com/cd/audio1.html
"TruBass is technology based on psychoacoustics and scientific knowledge of the human hearing system to generate bass sounds extending lower than a small speakers response so that a subwoofer is not required"
While not a real substitute for a sub in my book, it did punch out the bass sound quite a bit. This may be all that is needed for you. I did this recently while I was waiting for one of my amps to come in (had no sub amp) and for the time being it served it's purpose. The only thing is that if you want something like that you will have to get another HU. There is also a stand alone system by Waves called the MaxxBass 103 Signal Processor. You can add it in between your amp and HU, it has received good reviews.
Here is a quote from them:
"MaxxBass 103® Signal Processor
Using the MaxxBass 103 you can get rich, deep, booming subwoofer-quality bass from a car stereo without needing the traditional big subwoofer to go with it. In fact, nothing in the car has to look any different."
While I have not tried this, just letting you know what's out there. Here is the link to their site.
http://www.wavescaraudio.com/Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I have to agree with getting a sub. I have a 02 Silverado extended cab and put a sub and amp under the back seat. I still have access to my jack and no leg room is lost. My Wife uses the truck and needs the rear cab space. She still has plenty of room. BTW I am on the other side of 30
(40 on the 25th of Jan.) I can feel the bass but it does not rattle the truck and you can't hear it outside the truck.
If you don't get a sub, I hope your car sounds like my first car did. It was a 78 Camaro and all I had in it were 2 6x9s on the rear deck (Premier) and 6.5s in the front door (Premier) No amp, just a kenwood deck and a 10 disc changer. No trunk space left with the spare tire. Anyway, some how the sound was great in that car, even with out a sub or amp.
BTW, I have the speaker baffles from XTC I bought them for protection of the magnets and back of the speakers. I would think that they would also help like dynamat (Not as well though) because you are adding something between the metal surfaces of the speaker and door.Alpine 9855 hu
Polk/Momo MMC 460 (Rear)
Polk/Momo MMC 6500 (Front)
Polk/Momo MM 2104 Sub
Amp: JL 500/5
Wires: Street Wires
Sat Radio: Sirius PNP
______________________
Home
Kenwood CD 425M 200 disc cd changer
Denon AVR-2801 reciever
Mitsubishi HS-U577
Toshiba -SD1700 DVD player
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15 -
hrdhtdvr wrote:If you don't get a sub, I hope your car sounds like my first car did. It was a 78 Camaro and all I had in it were 2 6x9s on the rear deck (Premier) and 6.5s in the front door (Premier) No amp, just a kenwood deck and a 10 disc changer. No trunk space left with the spare tire. Anyway, some how the sound was great in that car, even with out a sub or amp.hrdhtdvr wrote:BTW, I have the speaker baffles from XTC I bought them for protection of the magnets and back of the speakers. I would think that they would also help like dynamat (Not as well though) because you are adding something between the metal surfaces of the speaker and door.
IF (big IF) I get a sub....it won't be for a while (currently strapped financially), and it would have to be something like the Infinity BassLink that has a built-in 200 watt amp, because it's small, won't take up additional room with cables/amp/etc. so I won't lose more cargo space. But the current system does sound pretty good without an amp....'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
I know exactly what you mean about being strapped for cash. I had to wait for 6 months before I could get my sub and amp. I would have put in the alpine mrvF450 (5 channel amp) but by the time I got the cash, I couldn't find one anywhere. Oh well, I am happy with what I have and that is what counts.Alpine 9855 hu
Amp: JL 500/5
Wires: Street Wires
Home
Mitsubishi HS-U577
Klipsch Speakers
Center: RC-7
L&R:KLF-20
Surrounds:RS-3
Sub: KSW-15
