Consolidating HT and 2-channel? Nope.
Early B.
Today I took my Jolida tube int. amp and tube CD player into the den where the HT rig is set up, hooked them up to the Soliloquy 5.3's and popped in a few CDs. I was shocked by what I heard. The Norh 5.1 bookshelf speakers on my 2-channel system totally spanked the Soliloquys in every category -- detail, presentation, articulation, bass clarity, etc. In fact, the Soliloquy's sounded dry and slow compared to the Norhs. The bass on the Soliloquy's sounded absolutely fantastic, at times, but generally, they added a muddy residue to the music. The same speaker cables and interconnects were used.
I didn't experiment with placement because of the limitations of the room, but the difference was so significant that I don't think it would have changed the outcome. When I first got the Soliloquys, I hooked them up to the 2-channel rig and got a similar result. At the time I blamed it on placement constraints.
The reason I tried this is because I considered consolidating my 2-channel system into the HT system (sharing fronts only). That way, for HT I could use the Jolida to power my fronts and pocket some cash by selling a few things. Now I have changed my mind. If I ever want to play music in the den, I'll just use the DVD player. Sounds pretty good, actually.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
