PSW505 & 404
boom19
boom19 Posts: 3
My front speakers are Monitor70's and I was wondering what I should set the frequency crossover at for my two sub's. What phase should I set them at? What frequency should the Monitor70's be set at if they are set to large aswell.
Post edited by boom19 on
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    The average answer will be 80Hz but really the best answer is play with it and it's whatever sounds best to you. Personally Id rather have a 'incorrect; setting that sounds better to be versus a 'correct' one.
    Also I dont know much but often there are no absolutes or 'correct' answers in this hobby. Always constant fiddling and tweaking... :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • PolkThug
    PolkThug Posts: 7,532
    edited January 2006
    Try setting the mains to "small" and putting the crossover to 80 or 60.
    *Assuming RCA cable for subs.
  • boom19
    boom19 Posts: 3
    edited January 2006
    That setting is for surround..correct? Music ...what would you say using the 70's and subs only.
