Speaker Placement (again)
Every now and then you should "tweak" your system by experimenting with placement. Here's what I did a few days ago -- I always knew my rear-ported HT fronts were too close to the wall, but sometimes you gotta appease the WAF gods. Then I got bold and moved them 5 inches forward into the room. Surprisingly, the wife didn't notice. Anyway, when I popped in a movie, I actually heard surround sound.
Now you may be thinking, how is it that Early B. wasn't getting surround sound on his 5.1 HT setup? Well, I'm glad you asked. You see, due to my room configuration, the seating position is on the rear wall, so I don't get the full 360 degrees of surround sound. However, when I moved the speakers forward, it appeared as though sound was coming from all around me. Very strange and quite unexpected.
Of course, the other result was that the sound was a bit louder at the same listening level, but I didn't have an appreciation for the full contribution the fronts make to the entire surround field. I guess it makes sense if you compare it to the soundstage and imaging properties of a good 2-channel music system -- every once in a while you become engulfed in a sea of sound. Pretty neat how that works for the fronts in HT, too.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
Post edited by Early B. on
I need to move mine also.
I mounted my rears on the vaulted ceiling just behind the sweet spot aiming down right on the spot.
I can barely hear them most of the time.
I think they need to be back a few more feet but I already have the wire ran and holes in the ceiling and everything so I am screwed till I want to take on a real project.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
That's cool. Speaker placement can be very tricky.
I did something similar in my rig the other day. Moved each speaker closer to the center by several inches and my sound improved. Better center image focus and mids.
If your wife didn't notice the 5" shift, try going for more:). -
Allways gota push or you can never find your boundries.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
did you move the speakers forward but NOT change the speaker distance in the receiver?
organ wrote:If your wife didn't notice the 5" shift, try going for more:).
Nah, better not. Right now they're about 9 ft. away. I almost feel they're right on top of me.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
aaharvel wrote:did you move the speakers forward but NOT change the speaker distance in the receiver?
Good idea. Maybe I should change it by 1 foot.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
