RT3000 Blown tweeter
Skynut
Skynut Posts: 2,967
edited January 2006 in Speakers
I guess I blew the tweeter in one of my RT3000 speakers.
The tweeter is not making any sound and has discoloration around the silver dome. In fact the black plastic is also discolored and slightly warped.
It looks like it actually started to melt.
A few questions for my fellow polkies are...
Could I have a bad cross over?
Is there an upgrade tweeter?
Is this the same tweet as my RT55's?
What should I do from here to fix this speaker and not blow the replacement?
Thanks.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
Post edited by Skynut on
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I would like to change out this tweet tonight so if anyone has any opnions I would appreciate them.
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    VR3 Posts: 29,662
    edited January 2006
    It should be similar if not the same to the RT55 tweet.
    Polk however no longer carries this PARTICULAR tweeter and carries that horrid silk as a replacement (all IMO) - I would just buy a pair of RT35 (or 35i, whatever matches) for your speakers - it'll only cost you about 70 more bucks and yall have midbasses and tweeters for future repair - you can sell the enclosures and xovers on ebay.
    However, I would email and make sure Polk dosnt use different drivers (ohm) on the dual driver speakers than the single ones...
  • Skynut
    Skynut Posts: 2,967
    edited January 2006
    I guess that is what I will do.
    I will take it out of my RT55's for now and look for replacement speakers later.
    Is the same tweet in the RT55 and the 55i's?
    Skynut
    SOPA® Founder
    DVD Onkyo DV-SP802
    Sherbourn 7/2100
    Sur FX1000
    SVS ultra plus 2
    Thanks for looking
    VR3 Posts: 29,662
    edited January 2006
    No...
    The I series had a reworked crossover, midbass, tweeter, and enclosure - otherwords - entirely different.
    Although it may work, doubt you could hear the difference really...
