halo projector headlights
hexumjunkie
anyone know anything about them....will they be brighter than my stock honda headlights
Post edited by hexumjunkie on
'halo projector'...? if you mean xenon lamps, then yes, they will likely be much brighter than standard headlights... if you don't mean xenon, then what do you mean?It's not good, very fundamentally simply not good. - geolemon
I think the general idea is they are a lot brighter than regular headlights with a specific cutoff point so that you don't blind everyone. It's all about limiting the beam of light by focusing it through a lens... thus the name "projector". A good setup though is going to cost around 300 bucks or more if you don't have anything other than regular halogen or xenon's in your car right now.Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
I need to get better headlights. The ones on my Ram are horrible.
I want some of those cool blue ones you see on some Benz's.polkaudio sound quality competitor since 2005
got 6-800 bucks? go for it, then... i looked into it for my car, decided that a mix of ultra-white and light blue-tint bulbs was the way to go...It's not good, very fundamentally simply not good. - geolemon
Ive found some at Advance Auto Parts for like $40 or so. Those are the ones?
http://www.partsamerica.com/ProductDetail.aspx?mfrcode=SYL&mfrpartnumber=9007CBTWIN&parttype=301&ptset=Apolkaudio sound quality competitor since 2005
you could look at what i believe are termed 'e-code' lamps (though i know not what that means)... here is what i'm talking about for my car...
these aren't halo lights, but are intended to provide a better beam pattern than stock, i believe...It's not good, very fundamentally simply not good. - geolemon
