SDA-SRS 2.3 and SDA-SRS 2.3tl differences?
housedj
housedj Posts: 44
edited January 2006 in Vintage Speakers
other than the obvious sl2000 and sl3000 tweeter differences:)
i have a pair of 2.3s and was wondering if they might have switched the dimensional array to the 2 driver array in the 2.3tls. does anyone have a wire diagram for the 2.3tls or own a pair that could verify this?
since i have the 2.3s i was considering transforming them into 2.3tls. since cabinets are identical would everyone agree that the value would go up? thanks for your comments
Post edited by housedj on
    F1nut Posts: 51,771
    edited January 2006
    Yes, the dimensional drivers in the 2.3TL's are the two alone.
    The money you'd have to spend would out weigh any increase in value.
  • housedj
    housedj Posts: 44
    edited January 2006
    i was considering upgrading the crossovers on the 2.3s as they are and getting the new tweeters. and i have 3 of the required 6510s so i would just need 1 more 6510, so i was thinkin for the price of getting 1 more 6510 it would be worth it to just make them tls
    F1nut Posts: 51,771
    edited January 2006
    Swapping drivers is only the beginning as the crossovers are very different, including different inductors. Forum member Decato did what you are thinking about, http://www.polkaudio.com/forums/showthread.php?t=35433
    Brian is a great guy and I'm sure he wouldn't mind talking to you about it.
  • decato
    decato Posts: 189
    edited January 2006
    Hi,
    This is not a project you undertake to increase the value of your possession. As already stated, the cost of the new parts will outweigh any possible monetary gains. I actually think you will lose money, since you will have a "hacked" model.
    Nonetheless, I went through several iterations of this procedure, going from the 2.3 to the 2.3tl and then to a hybrid 1.2/2.3tl. Nearly every part of the crossover, as well as the wiring harness and the drivers/tweeters, will have to be changed. It can be done, but I only recommend it if you want to improve the sound for your own enjoyment.
    -Brian
