Lsi9's or Rti8's?
KrazyMofo24
My budget is $800-$850 I can get the Lsi9's for $600 which would leave me enough to buy a denon 386s its a $400 receiever...I can get it for less than 300 since I work at Fry's. The sales people at fry's do not like the Lsi series, but I take your guys opinions over any salesman.
My other option would be to get the rti8's and the h/k 240 that'll be $800 total for that and a little under 900 for the Lsi9/denon receiver.
I know the lsi's require alot of power, but I plan to buy separate amplication when I get more money. How much would it cost to get a good amp to power the lsi's, and are they better than the rti8's?
Setup:
2 Channel: Vienna Acoustics Mozart Grand, T+A P 1230R, Primare SPA21, Oppo BDP-105
PC: Vienna Acoustics Haydn Grand, Cambridge Azure 650A v2 , Peachtree iDAC, Denon DVD-3800BDCI
If you work at Fry's.....can't you audition them to see which you like better?
Also, is this going to be a 2 channel only or are you planning to add more speakers??_________________________________________________
No doubt the LSi9 is a much better speaker than the RTi8.
Get the Lsi9.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
If you are going for music gear go with Lsi9s. For HT I would go with Rti8s. I find Rti8s on the bright side for music gear, but love them for HT.
IMO go with Lsi9s, if you dont like them later you can pass them on to us in the forum.
If you can audition both in your home environment. Your ear is your best friend.
GatorTheatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
Had the 8's loved em, till I had 9's that is. You can get a HK635 refurbed for around 500 that would be able to drive em till you want to upgrade. I haven't found it necessary yet, but I will in the next 6-8 months. If you plan on using the Denon, you should keep a fire extinguisher handy. ie: don't. HK is probably the least expensive Amp/receiver I would use with the 9's
www.harmonaudio.com-Ignorance is strength -
