Bipole Surround placement... corners or in more?
StopherJJ1980
Man Im askin a lot of questions today
Hope Im not gettin too annoying. OK so my FXi3's should be here any day now. My HT is set up in my living room. My surrounds are going to go on the back wall a few feet above my head because that is just the most convenient place to wall mount them.
Should I put these speakers directly in the corners or move them in a foot or two towards the middle and give them a little more 'room' to bounce sound around a bit? Or does it not matter where the reflection points are?
-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Polk FXi3's Surround
Cerwin Vega HTS10 Subwoofer
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Yamaha HTR-5740 AVR
Post edited by StopherJJ1980 on
I have seen 5.1 placement with the surrounds directly to the sides of the sweet spot with the null of the dipole lined up with the ear and have I seen diagrams recommended for 5.1 with the surrounds behind the listener in the corners angled toward the sweet spot. I am not sure how that would work with dipoles though. Get a couple of ladders out and try both. See which you prefer for your room. I heve them to the sides but I have a 7.1 set up. If you have no choice but to put them on the back wall...my guess would be corners but you have to experiment.Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000 A
Parasound HCA 1000
Oppo BDP 95
Von Schweikert LCR 4 Center
Totem Mask Surrounds X4
Sony PS3
Squeezebox Touch
wingnut4772 wrote:I have seen 5.1 placement with the surrounds directly to the sides of the sweet spot with the null of the dipole lined up with the ear and have I seen diagrams recommended for 5.1 with the surrounds behind the listener in the corners angled toward the sweet spot. I am not sure how that would work with dipoles though. Get a couple of ladders out and try both. See which you prefer for your room. I heve them to the sides but I have a 7.1 set up. If you have no choice but to put them on the back wall...my guess would be corners but you have to experiment.
Hi Darla,
Based on the title of Stopher's posting and Polk's advice regarding their Bipole-Dipole speakers, it would appear that Stopher intends to set his FXi3's to bipole mode.
I've got my surround back LC265i's speakers in the corners, but they have a special distance switch that adjusts the crossover to flatten response and tune out boominess caused by being closer that two feet to the walls. My guess is that since his speakers don't have this adjustment, he would want to get a few feet off the wall.
Larry -
Oh I see that now ....Sharp Elite 70
Anthem D2V 3D
Parasound 5250
Parasound HCA 1000
Oppo BDP 95
Sony PS3
Squeezebox Touch
Yeah theyll be wall mounted bipole-mode in back... Thanks for the input.-Stopher
Tempe, AZ
Setup:
Polk RTi8 Mains
Polk CSi5 Center
Yamaha HTR-5740 AVR
Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR -
try playing something back in surround sound that you're familiar with (for me it's the Ark scene at the end of Raiders). Sit in your normal listening position and listen to each surround speaker individually both in dipole and bipole mode. (Turn off the Stereo pair and center when doing this)
Dipole doesn't necessarily sound better on side walls and bipole doesn't necessarily sound better from behind. My room layout is a fubared corner setup and i have the both rear surrounds set to bipole: the side left surround set to bipole & the side right set to DIpole. You never know... -
I'd not have thought of that Andrew. How does it sound? I would think I'd get confused trying to map the phase relativity, but if it works that would be a rather niffty solution to some room limitations. Do you have a drawing or map of your placement?-Ignorance is strength -
