Help, surround sound not working!
demingm
Alright, I just bought the RM6900's, which I'm trying to hook up to my old receiver. Its a Technics SA-DX940, and it has all of the inputs needed to setup a 5.1 surround system. Looking at the Polk manual, I decided to try the Polk suggested subwoofer setup. I wired from my receiver to the speaker inputs on the sub, then from the sub to the two front speakers. Before I hooked up the rear sats, I wanted to see if my progress was working out so far. Maybe this is the problem, I wasn't sure if you needed everything hooked up before the surround would work. I highly doubt thats the case, but if it is then this is a simple solution. When I set my receiver to surround sound mode, I get absolutely no output. When I switch it to analog stereo, I do get sound from the front speakers, but obviously no sub or center channel. I'm hoping its just caused by not having the rear sats hooked up. Please help!
Post edited by demingm on
Are you using the digital input as your audio source? If so, make sure your tape monitor loop is disabled (if you receiver has one). On my old Pioneer, turning on tape monitor would disable digital audio entirely.No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR
