subs in single cab ranger
murdoc
okay i wanna know what can i put in my 1994 ford ranger single cab if anyone could help me out with this it would be greatly appriciated thanks.
Post edited by murdoc on
depends on what you're looking for (sound quality or spl or a mix) and what your budget is...It's not good, very fundamentally simply not good. - geolemon
I would think you could put a couple 10's in there. A sealed box for most subs on the market wouldnt be bigger than .7 ft3 which could easily be made to fit behind the seat of a regular cab Ranger.polkaudio sound quality competitor since 2005
Check out the mtx thunderform enclosures they are made for most vehicles. For ford rangers 93-97 they have a 10 inch sealed enclosure that fits behind the passenger seat without giving up leg room.
I am going to help my friend try to put one in his Ranger when he gets back from vacation later in the month. He is looking at the Sounsplinter RL-i8. We will be putting an MTX amp in there too . He has the extended cab so we should have a little more room.
If you do not have the extended cab, I would look into the prefab enclosures. My friend bought a Q-Logic one for his F-150 and put two JL 8's in there. It is being pushed by a Kicker ZR240, and the bass output is very nice.Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I agree with the single sub route. Ive driven trucks most of my life and have used both single and double subs and while the double subs have more output and piss off more neighbors, the single sub blends better with the midrange and sounds more musical.polkaudio sound quality competitor since 2005
thanks alot for all of the info i appreciate it!
i have a single memphis mojo in my 86 nissan sounds better than ne thin i ever put in my truck and i have had up to four subs in there b4
