Thinking about upgrading my PSB Stratus Silveri's to LSi 15's or 25's..
chase17
chase17 Posts: 6
edited January 2006 in Speakers
I have PSB Stratus Silveri's,Stratus C6i center,Image 10S sides,old JBL rears.. Question is, would it be a huge upgrade to LSI25's,LSIC center,LSIFX sides,LSI7 rear surrounds ? I mostly do HT but do listen to music as well. I've got a Sony SCD-C555ES changer. I also power everything with a B&K200.7 amp through a Pioneer Elite 56txi receiver. Any input would be appreciated
ps. i can get a really good deal on the speakers. Authorized.
Post edited by chase17 on
  • StopherJJ1980
    StopherJJ1980 Posts: 267
    edited January 2006
    As far as whether they'd be better, I dont know, never listened to PSB...
    but if you do get the LSi's get the matching LSi surrounds, not the FXi's...
    timbre match, timbre match, timbre match :)
    -Stopher
    Tempe, AZ
    Setup:
    Polk RTi8 Mains
    Polk CSi5 Center
    Polk FXi3's Surround
    Cerwin Vega HTS10 Subwoofer
    Yamaha HTR-5740 AVR
    Upstairs R50/R15/CS1 5.1 setup w Pioneer AVR
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2006
    If you already have PSB gear then stick with is. However, if you do decide to upgrade, definetely Lsi 15's. I liked them alot better then the PSB line. The PSB's seemed more comparable to the Rti line.
  • chase17
    chase17 Posts: 6
    edited January 2006
    Yeah, that was a mistake typing FXI5's. Edited. I run 7.1 - Do the LSI7's timber match the drivers for rear surrounds or should i do 9's ? This is 90% an HT setup.
    Also, if i did go LSI25's, how do the powered woofers incorporate for the best sound possible? My receiver has MCACC auto cal but the powered woofers are something i've never delt with before. My sub is an SVS PB2 plus...lots slam there.. Can you cross at 80Hz and still make use of the built in subs and how... A little confusing..
    Thanks gang
    -Chip
  • McLoki
    McLoki Posts: 5,231
    edited January 2006
    The 7's work great with LSi15 fronts. The entire LSi line timbre matches well with each other. I agree - get the 15's over the 25's. The 15's sound great and it is really hard to get the 25's to not have to much or to little bass.
    Michael
  • chase17
    chase17 Posts: 6
    edited January 2006
    Ok. So far it seems people favor the 15's over the 25's. Has anyone successfully incorporated the 25's into their HT? I'd like to hear from these people as well before i go further. I have the juice to drive just about Anything with the Ref200.7 amp.
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    LSi15 over the LSi25... with a strong separate amp, you can have better control of the LSi15's woofer than you would with the LSi25 IMO. The 15 tends to sound cleaner, especially in the bass regions of the sonic presentation.
    That extra cash you save, you should use it on a bonafide sub - like an SVS or something similar.
  • chase17
    chase17 Posts: 6
    edited January 2006
    I've owned SVS subs since their inception. PB2+ currently (since Sept '03). Thanks for your input Joey. See post #4.
  • Joey_V
    Joey_V Posts: 8,600
    edited January 2006
    Well.... I guess that makes it an easy choice - LSi15 by far.
    No contest.
