RCA/coax interconnect question.
trubluluc
Ok,I should know this but.....
besides the fact that "Digital Coax" cables are sold individually, instead of being sold in pairs as "Analog" cables are.
Is there any difference really?
-Luc
-Luc
Post edited by trubluluc on
No, Luc, there actually are no such things as "digital" and "analog" cables. Copper wire carries both digital and analog material without any problem. The standard for digital connections calls for a 75ohm impedance and some "analog" cables have a lower impedance than this, but for digital connections of the length typically used in home audio the impedance mismatch is insignificant.
This confirms what I have always thought, but didn't know for sure.
To hear Cable manufacturers talk, you would think you were breaking the law not using a "Digital" classified cable for a digital signal.
-Luc -
Hold up, there IS a caveat. I have had RCA "analog" IC's that would not work for digital transmission reliably----Audioquest Sidewinder, to name one. My DAC would intermittently loose "lock" with this cable being used as a digital coax. Why? I have no idea, just relaying what I experienced. Just a heads up...
Video cables will work as a digital coax, but some analog audio cables will not perform reliably.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
Good Read. THANKS Emlyn!
So I guess the answer is yes and no. Got to love gray areas.
If I'm understanding this correctly, if the analog cables are a newer design,
with tighter tolerances in passing a true 75 ohm signal, then yes,
analog cables will work fine for digital.
And do to the tighter tolerances, digital cables will definitely work well for analog signals
-Luc -
Your best bet is to get a "dedicated" digital coax. No need to spend a ton of money, see the DH Labs D-75. $69 bucks and highly respected.
http://www.upscaleaudio.com/product.asp?itemid=356&catid=70Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
John K. wrote:No, Luc, there actually are no such things as "digital" and "analog" cables. Copper wire carries both digital and analog material without any problem. The standard for digital connections calls for a 75ohm impedance and some "analog" cables have a lower impedance than this, but for digital connections of the length typically used in home audio the impedance mismatch is insignificant.
With respect, I will catagorically disagree with you John.
If I had to pick I would rather use a digital(75 Ohm) cable as an analog jumper before using an analog cable as a digital(75 Ohm) cable.
HBomb***WAREMTAE*** -
RG-6 coax is RG-6 coax is RG-6 coax. It will work for either digital or analog. An analog RCA cable is not coax. (edit - should have restricted that to 75 ohm coax)
Ive read that a video cable (75ohm standard) is better than using a audio rca cable
its a coincidence because Iam going through this exact issue today
after doing optical for awhile I want to go back to Coax...I used to have a XLO coax but no longer,
think Ill go with a good video cable as a coax
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
video and digital audio is 75 ohm and is inportant to ohm match but audio cables dont matter. you just need a quality one. i used a 75 ohm carana cabble that is custome made for my sub and it is awsome. i will make vid and digital cabbles for any one on the bord for cost +shiping.
what it cost me is about 1/2 of what sigonal and blue jean for parts. but they proabley get a better price on parts than me. -
Is Coax audibly better than Optical?
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
no LSI9, and vice versa- but it's been said over long runs it's better to use Optical due to rf interference (or something like that)
cool name btw
