Multiple main speakers
Davidv
Davidv Posts: 94
Does anyone have more than one pair of mains hooked up? If you do how should they be hooked up? In series or with a jumper?
Also are there any benifits, or drawbacks to doing this(other than less power to each speaker if hooked up in series)?
My old setup was:
Mains: RT10
Center: CS400
Rears: fx500
sub: psw404
I got an awesome deal on a pair of RT12's and replaced the RT10's as my mains(which gave me a fuller sounding front stage, that I was hoping for), and then as an after thought ran a jumper to the RT10's and I swear the soundstage improved again.
Any input appreciated.
Thanks,
David
Beer on tap is great, until the keg runs dry and the liqour store is closed!:D
Post edited by Davidv on
  • cnjvh
    cnjvh Posts: 253
    edited January 2006
    Be sure to wire them in series. This results in around a 16 ohm load to the amp and will prevent overcurrent. The larger load will simply cause them to play quieter which you can adjust for. Wiring them in parallel would drop it down to 4 ohms which could be bad for the amp (some here have meausured these as lower than 8 ohm speakers so the effect in parallel could be even worse than 4 ohms).
    No earth robot is going to tell ME which button to press!!
    --Stuff--
    Front: Polk Audio RTi12
    Center: Polk Audio CSi5
    Surrounds: Polk Audio RTi8 (x4)
    Sub: SVS PB10-ISD (Dual)
    AVR: Denon AVR-3805
    Blu-Ray: Panasonic BD30
    Display: Sony KDL-55NX720B
    STB: Xfinity X1DVR
  • Davidv
    Davidv Posts: 94
    edited January 2006
    So by running the jumper you are saying that I have them hooked up in parallel.
    After I looked again at the description for each type of connection, it seems like it may be hooked up in parellel, but I am not sure.
    I hooked the wires from the amp to the rt12's lower hookups, left the gold biwiring strips in place and ran a jumper from the upper connection on the rt12's to the rt10's. Is that running them in parallel?
  • cnjvh
    cnjvh Posts: 253
    edited January 2006
    Yes, this is parallel and bad. To wire them in series (leave the jumpers on place and use either top or bottom for this):
    red on amp to red on speaker 1
    black on speaker 1 to red on speaker 2
    black on speaker 2 to black on amp
    Good luck! Many people find that running multiple sets of speakers muddies the sound due to frequency cancellations but if it rocks to you, go for it!!
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • Davidv
    Davidv Posts: 94
    edited January 2006
    Thanks for all the help.
    I hooked them up in series last night and listened. Then I hooked up just the rt12's, then just the rt10's. I did that 3 times listening to the same thing each time and the rt12's by themselves won the battle. Heck they even sounded better than when I had the rt10 & 12's hooked up in parallel.
    So the rt10's move down to the 2ch rig.
    It is disappointing having to move them. The 12's and 10's look too good sitting next to each other at the front of the room. Oh well.
    Thanks again for being the only person to respond. You helped me out alot!
    David
  • cnjvh
    cnjvh Posts: 253
    edited January 2006
    glad to do it :-)
    --Stuff--
    AVR: Denon AVR-3805
    STB: Xfinity X1DVR
  • doggie750
    doggie750 Posts: 1,160
    edited January 2006
    David
    need stronger amp! to run 2 mains........ but you will Overkill the center......
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
