Yamaha Receiver
Ahmedmo
Ahmedmo Posts: 19
edited January 2006 in Speakers
Hi all, i purchased pair of RTi10 as my main front speakers, CSi5 center & FXi3 surrounds!! It's a very nice combination i beleive!! I have an older Sub "JBL E150" which i think it's OK for now!! My question is about my Yamaha RX-V757, it should be a very nice machine for these speakers OR i should get a dedicated AMP for the RTi10s?? My room is 15x13. Appreciate your input please!!
Ahmedmo
TV: Loweve 93102 -40' CRT
AV Amp: Yamaha RX-V4600
DVD player:SONY DVP-CX985V
Front:Lsi 15s
Center:LSic
Surround:Fxi3
Sub:PSW 505
Post edited by Ahmedmo on
  • Frank Z
    Frank Z Posts: 5,860
    edited January 2006
    What are the specs on the Yammie?
  • MSkeezer
    MSkeezer Posts: 1,183
    edited January 2006
    100 watts x 7. The reviews for it have been very good. I'd say get it and add a 2 channel amp for your 10's. You should be set.
  • John K.
    John K. Posts: 822
    edited January 2006
    Ahmed, yes, you've bought a very nice set of speakers. Your listening room is relatively small and your 757 should have more than enough power for your use. Keep in mind that at a comfortably loud average listening level your RTi10s will be using about 1 watt and that even brief peaks aren't likely to use more than 100 watts, most likely less, in your room.
  • dkg999
    dkg999 Posts: 5,647
    edited January 2006
    Very nice setup. The Yammies power is 100w channel in marketing speak. If you drive your system at relatively loud listening levels, you won't be doing the RTi10's justice and the Yamaha HTR will run hotter than it needs to. I have the HTR-5790 (same as the RXV-1400). No problem starting out using just your receiver, however I would recommend getting a separate amp for your RTi10's at some point. The CSi5 would eventually benefit from some additonal power also. The Yamaha HTR has a very good pre/processor in it, it's amplifier section is a little weaker as far as capabilities.
    DKG999
  • Ahmedmo
    Ahmedmo Posts: 19
    edited January 2006
    Thanks for the great advices guyz,just to complete the picture, which 2 ch Amp would you reccommend??
    Ahmedmo
    Front:Lsi 15s
    Center:LSic
    Surround:Fxi3
    Sub:PSW 505
  • Ahmedmo
    Ahmedmo Posts: 19
    edited January 2006
    Hello back, i made a research & found couple of Amps, Onkyo one of them, what do you reccommend guys? How much wpc Amp i should get to drive the RTi10s??
    Ahmedmo
    Front:Lsi 15s
    Center:LSic
    Surround:Fxi3
    Sub:PSW 505
  • Willow
    Willow Posts: 11,057
    edited January 2006
    FWIW, I used to use an RXV540 rated at 80 or 85wpc. I recently got the HK 335. There is no way the yammy is pushing 85wpc. Great receiver and all (yammy) seing as you have pre-outs you will want to take advantage of them. I plan on it.
  • kmartin971
    kmartin971 Posts: 236
    edited January 2006
    Go with the V2600
    TV = WS65611
    Pre-Amp Onkyo 830
    Amp Aragon 2007
    Panamax 5510
    Towers = LSi25s
    Center = LSiC
    Side Rear (2) = LSiFX
    Rear (2) = LSiFX
    JBL S120P II
    Sony Upconverting DVD Player
    XBox
    XBox 360 (Wireless connection live and media center enabled)
    PS3
  • Ahmedmo
    Ahmedmo Posts: 19
    edited January 2006
    That's what i meant, i mean to attach a dedicated 2 ch amp in the preout to the yammie 757 , to drive the RTi10s!! Any suggestions for the 2 ch amp??
    Ahmedmo
    Front:Lsi 15s
    Center:LSic
    Surround:Fxi3
    Sub:PSW 505
  • cfrizz
    cfrizz Posts: 13,415
    edited January 2006
    The number of 2 channel amps you can buy is endless. How much money do you want to spend, & would you consider buying used?
  • Ahmedmo
    Ahmedmo Posts: 19
    edited January 2006
    I would spend 200-300 Dollars ... and YES i won't mind buying a used one!! Any suggestions guys?
    Ahmedmo
    Front:Lsi 15s
    Center:LSic
    Surround:Fxi3
    Sub:PSW 505
  • dinnu
    dinnu Posts: 33
    edited January 2006
    You can get a Rotel 980BX (120 watts/ch) for about $275. There is one listed on Audiogon right now (no affiliation).
    http://cls.audiogon.com/cgi-bin/cls.pl?ampstran&1141948922
    I know it is out of your range but there is also a Rotel 993 (3 ch @ 200 w/ch) listed on Audiogon for $450 and you can probably negotiate the price (no affiliation).
  • Ahmedmo
    Ahmedmo Posts: 19
    edited January 2006
    THANX Dinnu for your help :) I really appreciate that!!
    Ahmedmo
    Front:Lsi 15s
    Center:LSic
    Surround:Fxi3
    Sub:PSW 505
