Wanna download some gasoline?
LiquidSound
LiquidSound Posts: 1,261
edited April 2024 in Clubhouse Archives
Two Channel Main
Receiver - VSX-54TX
Mains - Csi40's
Sub - Spiked Velodyne Cht-8 On Spiked Landscaping Stones
"If you could put speakers in a needle, I'd never see him again..." - My Girlfriend
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2006
    Hmm. When I'm standing beside the pump in the cold, all I want is my gas.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • michael_w
    michael_w Posts: 2,813
    edited January 2006
    I could see if it took a while to pump gas but since I worked at Esso for a while I know it won't quite work. When things get busy trying to get people their gas as fast as possible is the main goal. It only takes a couple minutes to pump and even when it isn't busy I'm sure people would rather get on their way than spend extra time at a gas station.
    Not sure if it'll work for you but heres a little trick to get your gas pumped faster - when you're pumping your gas on one side of the pump walk over to the other side of the pump and get it ready to pump as well. Say you want $20 of regular - get it going and then walk to the other side and pick up the delie and press the regular button. The pump will think it's going to have to pump from that side as well so it doubles what it can pump. That excess goes to the pump that is actually pumping and you get your gas pumped twice as fast as you normally would.
    Now I don't really suggest you do this on your own but if you're just standing there and in a hurry ask the atendant (if it's full serve) if you can try it... otherwise they might get a little weirded out if you try it.
  • BobMcG
    BobMcG Posts: 1,585
    edited January 2006
    a gas pump powered by Windows CE, which the company envisions as a terminal you can use to download music files, watch videos or download and print coupons while you fill your car.
    Like it takes long to put say $20 or $30 into your tank these day at $2.50 a gal. :rolleyes:
  • audiobliss
    edited January 2006
    Very interesting. Thanks for the tip.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • michael_w
    edited January 2006
    Yeah, careful with it though. They might give you **** for trying it or it occasionally starts to fill the hose with gas and will actually show on the meter that you've pumped a few cents. As an employee I did it all the time but as a customer I'm not sure where you'd want to draw the line. Use your discretion ;) It was very handy for when you had a truck come in and need like 30 or 40 gallons.
  • Mazeroth
    Mazeroth Posts: 1,585
    edited January 2006
    This Ovation pump has to be one of the most stupid things I've ever heard of. Hell, how about putting a computer in each stall of a public restroom so I can check my e-mail while dropping anchor.
    michael, thanks for the tip!
  • bobman1235
    bobman1235 Posts: 10,822
    edited January 2006
    Some Shell stations have the little TVs on them that basically just show ads. That's entertainment enough - something that showed little commercials, or even just a radio station, at least it's something I guess. Anything interactive or that could even be too interesting is a bad idea, it'll just slow things down and cause problems.
