2 amps on a 1 pre out head unit?
eatsleepplayscc
eatsleepplayscc Posts: 27
edited January 2006 in Car Audio & Electronics
I just found out that I have another obstacle in my way of completing my system... Is there anyway possible to have an amp with subwoofers and an amp with speakers both hooked up to the headunit if the headunit only has 1 pair of preouts?
Post edited by eatsleepplayscc on
  • skydeaner
    skydeaner Posts: 187
    edited January 2006
    Sure get some splitters from radioshack and you'll be all set, I think it will then only give half the voltage to each amp though, so remember that when setting gains.
    Fiberglass reminds me of peanut brittle, only fiberglass tastes better!
  • MacLeod
    MacLeod Posts: 14,358
    edited January 2006
    Y adapters.
    You can pick some up at any electronics store.
  • 1996blackmax
    1996blackmax Posts: 2,436
    edited January 2006
    If the amplifiers have pass throughs you can also use those to pass the signal to the other amp.
    Alpine: CDA-7949
    Alpine: PXA-H600
    JL Audio: 10W6v2 (x2)
    KnuKonceptz
    Second Skin
  • skydeaner
    edited January 2006
    Wow that's a nice one macleod. What do those run like 20 bucks? hehe
  • cam5860
    cam5860 Posts: 632
    edited January 2006
    The only thing about the y cable is it's going to kill your signal. Lets just assume you have a 2 volt signal coming from headunit with the y cable. Thats going to split the signal only giving you 1 volt per amp.
  • audiobliss
    audiobliss Posts: 12,518
    edited January 2006
    Hence the pass-through option on the amp would be much more desirable, no?
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    Klipsch RF-35, RB-51ii
    [Car Audio]
  • exalted512
    exalted512 Posts: 10,735
    edited January 2006
    get the y-splitters and a line driver, problem solved
    -Cody
  • MacLeod
    edited January 2006
    Or just upgrade to a better head unit. That would be the best option, although it may not be the most cost effective.
  • audiobliss
    edited January 2006
    That was my first thought, as well. And, even if it isn't the most cost-effective solution now, it will probably end up being, as you won't have a y-adapter and power-line driver thingamabob-dohicky-whatchamacallit-device-tool-gadget (I'm good with names :D) laying around unused when you do upgrade your HU. And you will, if you ever get into car audio.
    Jstas wrote: »
    In Use
    Epson 8700UB
    In Storage
    [Home Audio]
    [Car Audio]
  • nadams
    nadams Posts: 5,877
    edited January 2006
    Most amps have a pass-through for a second amp... don't they?
    Ludicrous gibs!
  • eatsleepplayscc
    edited January 2006
    wow it's been so long since i've checked the forums.. so if my subwoofers are already underpowered slightly, would using a y splitter make it worse and lose even more power?
  • 1996blackmax
    edited January 2006
    If you set your gains correctly it should not be an issue.
    Alpine: CDA-7949
    Alpine: PXA-H600
    KnuKonceptz
    Second Skin
  • unrealii
    unrealii Posts: 268
    edited January 2006
    Some amp passthroughs are just like splitters to watch out for that.
    LSIm system on order =D
    Currently listening to innovation...
    Prior car systems:
    Nissan Maxima - Eclipse CD5030, Eclipse HDR109 HD Receiver, Eclipse PA5422, Eclipse PA5532, Polk SR 6500 (Front), Polk DB6510 (Rear), Image Dymanics IDQ10, active x-over setup
    Toyota MR2 - Eclipse CD5030, Eclipse HDR109 HD Receiver, Blaupunkt THA 555, Polk SR6500
