CSi3 Owners
Mike Reeter
Mike Reeter Posts: 4,315
edited January 2006 in Speakers
Can anyone tell me what the total inverted height of the CSi3 is? This would be the measurement from the base to the very top edge when the speaker is "upside down" pointing upward...
Need to find out whether it will fit into a cabinet or not...
Many thanks,Mike
Post edited by Mike Reeter on
  • janmike
    janmike Posts: 6,146
    edited January 2006
    Directly from the Polk web site
    Dimensions
    Cabinet Size 6-7/8" H x 20" W x 9-1/4" D
    (17.46cm H x 50.80cm W x 23.50cm D)
    Michael ;)
    NORTH of 60°
  • Mike Reeter
    edited January 2006
    Dimensions
    I checked specs first,just did'nt know if the height was a differant measurement when inverted...
    Thanks,Mike
  • janmike
    edited January 2006
    Mike,
    Not sure about that as I own a CSi5.
    The dimensions for the CSi5 are:
    Cabinet Size 7-11/16" H x 24" W x 14-1/2" D
    (19.53cm H x 60.96cm W x 36.83cm D)
    I verified the measurements on the CSi5 and the only one that appears to be out a little is the depth. 14.25" instead of 14.5".
    Michael ;)
    NORTH of 60°
  • Mike Reeter
    edited January 2006
    I also have a CSi5,getting ready to revamp another system thats in our family room with some smaller Polks;Rti4's and a CSi3...The centre would be below the Monitor pointing upward,the CSi3 and gear will be in a built-in cabinet,so room constraints are a question...
    Thanks again,Mike
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2006
    Inverted - 7.5"
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • Mike Reeter
    edited January 2006
    Ron Temple wrote:
    Inverted - 7.5"
    Ron,Thanks for your time&trouble...I thought there would be a difference...but not much at all...Mike
