Power conditioners
Skynut
So do any of you believe they make a difference and which one would you recomend.
I currently use the Panamax 5510 and am thinking about another one since I have used up many of the outlets with large aftermarket power cords.
I did not really notice any improvement to my sound but my power is not all that bad in my area. I do however feel better knowing that my equipment is protected better than a regular surge protecter will provide.
What are your thoughts.
Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking
Post edited by Skynut on
I use a simple belking surge/filter bar and I'm happy .......................................................................................................................................................................................................For now
I currently use a surge protector as I've never been sure a power conditioner won't subtract/add "other" things to the audio signal. My main system is always unplugged when not in use (just in case). This in one area that puzzles me and I just need to do more research. One of those expensive power re-generators from Panamax may be in the future.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
I have the Panamax 4200? 4100? I dunno 4..something. Basically a glorified multi-outlet. I tried and did not like power conditioning (Monster HTS).Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
I think I like the peace of mind the most.
Mine went into protection mode once and if I remember right I had to turn it off and back on to reset it. (If I remember right)
Aside from easing my mind it also looks cool in the rack.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thanks for looking -
I feel the need to use a power conditioner now (since I can see my lighting fluctuate a lot), and at my previous residence I had to, or my AVR would go into protect.
i live in a dorm room....
soo i thought a power conditioner would be a good diea. I don't have a great one but I feel it protects my equipment a little better from the constant small spikes going through the place
ChrisReceiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt -
I'm running a Equitech Son of Q balanced power unit. It made a immediate difference on my video ( I actually had to re-calibrate the color) & audio. The music was more robust & cleaner sounding."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
PS Audio Power Director 4.7 with a PS Audio Statement power cable to the wall for the home theater gear.
PS Audio UPC 200's for stereo systems. -
PS Audio UPC-200's with PS Audio Statement power cords. They offer both conditioning and surge protection, but most importantly they do not add or take away anything.Political Correctness'.........defined
President of Club Polk -
I use a Tripp-Lite LCR 2400. Works fine for me.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
Sweet responses, I like to hear the names and model numbers so I can look some of them up.
I am curious which ones are better than mine.
Although I am pretty happy with mine.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
pearsall001 wrote:I'm running a Equitech Son of Q balanced power unit. It made a immediate difference on my video ( I actually had to re-calibrate the color) & audio. The music was more robust & cleaner sounding.
Finally glad to see that I am not alone; Balanced Power Technologies BP-2.5 with Bybee filters and differential noise filter (HFC-30 is the current accessory) for the entire system. Same problems, sorry, I mean benefits noted above.
Since you say that your power is not bad in your area, take your system to the next level with balanced power. A BP-2 with the HFC-30 filter should power your entire system.
I believe the 5510 has a small transformer in it. Are you using balanced power option for your source component? -
I use power conditioning because my power runs close to 130V and I do not want to ruin my equipment. I have converted to using all 130V light bulbs because the 120V bulbs would be lucky to last a month.
-Lou -
Panamax 5400EX.
Like you, I like the ease of mind being protected gives.
I heard the noise test, listening to unfiltered power vs conditioned power, and it convinced me.
Got to love the coooool blue light display.
-Luc -
I just ordered and rec'd a second Panamax 5100 for the bedroom HT and 2 ch. system. If anyone is interested, Panamax-sales.com is clearing them out for $249 with free shipping because the new EX line is replacing them. The EX line has some nice features, however if you can live with the previous line they have some great deals. Ya don't get no cool blue lights thoughDKG999
Music System: Magnepan 1.6QR, SVS SB12+, ARC pre, Parasound HCA1500 vertically bi-amped, Jolida CDP, Pro-Ject RM5.1SE TT, Pro-Ject TubeBox SE phono pre, SBT, PS Audio DLIII DAC -
MONSTER CABLE MP-HTS3500MKII Powercentre. Works well for me. 118V to 120V steady in my area. Cool analog blue light volt meter.Theatre System 5.1
Sumsung HP-S5053 plasma
Receiver Denon AVR 3806 Pre/Pro
Parasound HCA 1500A amp (front L/R)
Parasound HCA 1000A amp (centre)
B & K AV5000 amp (bi-amp + surround)
Dynaco ST70 tube amp (Herbie HAL-O9)
polkaudio Lsi15 (Cherry) 2-channel
polkaudio Rti8 Front (Cherry)
polkaudio Csi5 Centre
polkaudio Rti6 Surround
polkaudio PSW1000 Subwoofer (Cherry)
Original A8T CD
Pioneer DV-275 DVD Player
MONSTER CABLE MP-HTS3500MKII Powercentre -
jmierzur wrote:Finally glad to see that I am not alone; Balanced Power Technologies BP-2.5 with Bybee filters and differential noise filter (HFC-30 is the current accessory) for the entire system. Same problems, sorry, I mean benefits noted above.
I am using the balanced option.
I am also interested in what is better and why. I am thinking about replacing it with something better if there is something out there for under $1000.00
Do the Bybee filters help enough to be worth the investment?
Aren't they for each interconnect?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
Thread I composed for balanced power. Read the two reviews of BPT units linked in the last post.
Thread that includes my posts on Bybee Quantum Purifiers. -
I have 2 Monster HTS-2500's in my HT rig. It does both power conditioning and surge protection.If...
Ron loves a film = don't even rent. -
Ron-P wrote:I have 2 Monster HTS-2500's in my HT rig. It does both power conditioning and surge protection.
Do you run them from different circuits or the same outlet?Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
They both run off the same dedicated 20 amp circuit. One is used for the 6 amps and the other is used for the dvd player, Outlaw 950, Z3 and the ICBM.If...
I love my Monster HTS, besides looking good I feel it does help when you play the HT at low volumes, keeping the power steady.
No here mentioned a great feature of having a power conditioner;
Many like mine come with switchable sockets which allows me to turn on/off ALL my audio components by turning on/off my preamp
Audio Physic Scorpio II
Pathos Logos
MIT Shotgun S3
Bada HD-22 CDP -
Ok.
Just had the opportunity to test out an Isotek multi-way powerconditioner. I've already upgraded my house wiring so it's benefits on the Audio side was only subtle but present. But on the video side this is where it shined.
Images on the plasmaTv became more crisp, contrast and texture more defined. Small text on screen became sharper and more readable. Does the same with crt's as well.
Yup, powerconditioners do have their benefits.
Also had a chance to try-out their powercord. Listended to some 'Oscar Lopez' and I noticed the individual guitar strings were more audible now.
All this is both good and bad coz' now I have to buy them.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
Speakers: Tannoy DC sensys speakers, Paradigm Servo15 Sub, Velo Spl-1500r
Conditioner: Isotek -
So the majority think it is benificial.
Thats good, like I said earlier I really like mine if for nothing more than piece of mind.Skynut
SOPA® Founder
DVD Onkyo DV-SP802
Sherbourn 7/2100
Sur FX1000
SVS ultra plus 2
The poll is rather hard to make for me. Since I don't consider a powerconditioner as a means to protect equipment, but mainly to filter out noise in the line that degrades overall performance of an AV system. I use switch boxes that shuts off power going to the AV system when I'm not using them.
I still use a separate Stac avr for the plasmatv before it goes into the powerconditioner.Gear: Rotel RC 1082, Rotel RSP 1068 pre/pro, Rotel RMB1077 amp, Cayin CDT 15a CD player, S301 bluray.
I use a Panamax 5500EX and am very happy. I completely believe in line conditioners, both in terms of protection and performance enhancement. I saw a big difference in pq on my tv with the panamax, and I was using a HTS5100 form monster before. As for sound, all I know is my system sounds better than ever now that I've got the Panamax, some decent cables, and the best AVR out there in my opinion.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner
