More than one sub?
Can I hook two subwoofers up to my system? I have my single sub hooked to the left and right main speaker terminals and the speakers hooked to the subwoofer. Can I hook a single subwoofer to the left and the right main speaker terminals and then a left and right main speaker to the terminals on the subwoofers? I would appreciate any information on this subject. Thank you.
Post edited by arcin' marty on
  • Willow
    Willow Posts: 11,246
    edited January 2006
    Welcome,
    You don't have a sub out on your reciever ?
  • hoosier21
    hoosier21 Posts: 4,420
    edited January 2006
    why noy one sub on each speaker?
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • Willow
    edited January 2006
    I sure it could work. I was thinking if he had a sub out and used a splitter for the two he could stack or one on each side. Otherwise I do't see why he couldn't hook one sub to each speaker using speaker cable.
  • MLZ
    MLZ Posts: 214
    edited January 2006
    Wouldn't a second sub on sub-out be used for LFE
