Tripp Lite isotel
jfb4548
jfb4548 Posts: 168
edited January 2006 in 2 Channel Audio
I have several differant Tripp Lite Power Protections / Surge Suppressors not being use at work so I thought I might take um home and protect my audio equpt. Are these type of units enough to run audio stuff and not effect the sound in a bad way? They are both rated with a "full load draw" of 12 amps or 1440 watts. My thinking was to use one for my ELP, Jolida and V10X3 tube buffer and the other for my Mc 7270 power amp. Am I crazy to do this?
Thanks as always!
John
The model # is ISOTEL 6 ULTRA if that helps!!
Post edited by jfb4548 on
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    If this is the "isobar" variety (isolated filtering), then go for it. I have two of 'em. Works as well as my $500 Monster Power Center.
    "God grooves with tubes."
    F1nut Posts: 51,776
    edited January 2006
    You'll need to find out what the max. amp draw is on your amp, the rest of your stuff shouldn't be a problem.
  • jfb4548
    jfb4548 Posts: 168
    edited January 2006
    Thanks guys! You ROCK!
