Recommendation for battery
Wattsup
I am in need of replacing the start battery in my 2004 Frontier. Without going to the extreme to set up a seperate battery for aux. use, can someone recommend a good dual purpose battery. By dual purpose I mean one that will be used for starting yet last a couple years of also powering my system while driving. My system draws at an estimated combined rated maximum (amplfiers, engine elec. lights ect. of roughly 70 or so amperes) I tend to only listen to my system while actually driving, especially while on the freeways. (no need to make everyone else to have to listen to what pleases me) All help appreciated
Post edited by Wattsup on
red top
Duralast and Die Hard are my favorite. They also cost $80 less than an Optima. Im running a max of 70 amps in my system as well and am using the stock alternator and battery and have no issues at all.polkaudio sound quality competitor since 2005
MacLeod wrote:Im running a max of 70 amps in my system as well and am using the stock alternator and battery and have no issues at all.
I have a couple of energizers i got from pep boys. Something along the lines of 800-900CCA(yes, CCA). I like em. Red tops are good as well.
Im more than likely going to be getting a DieHard truck battery when its time for me to replace my OEM. Its 700 CCA but 135 minutes reserve capacity which is the highest I know of. $90
But then the Duralast Gold looks pretty good as well with 875 CCA and 110 reserve capacity for $65.polkaudio sound quality competitor since 2005
Cold Cranking Amps.
Im not sure of the textbook definition for it but basically it is a measure for how many amps the battery is capable of spitting out in one discharge to crank your car on an extremely cold morning.
Reserve capacity (or capacitator ) tells you, in minutes, how many long the battery will run your vehicle is the alternator suddenly dies. Anything over 120 is excellent.polkaudio sound quality competitor since 2005
I use Optima Yellowtop and that works great. I have be using Optimas for several years and it works relly good.
The only thing that is better than one Optima is two Optimas:)A simple system = Pure music! -
Iv'e been using Die Hards for years. My last one is a Die Hard Rangehandler. I will however give the Optima a shot .Alpine: CDA-7949
Alpine: PXA-H600
JL Audio: 10W6v2 (x2)
KnuKonceptz
Second Skin -
I am leaning towards that one.Alpine: CDA-7949
Alpine: PXA-H600
KnuKonceptz
Second Skin -
If you plan on having the option of running your system for a good while with the engine off, keep in mind that running an optima red top right down will snuff it early, and get the yellow top instead. There are online gripes about optima red tops not taking a charge if drained to 11 volts.
If the idea is to have some reserve in the battery should your system draw more (during transients in your music) than your alternator is capable of providing, a red top or other quality battery would do the job. I've installed a red top and its been great.
Most newer OEM batteries should be replaced at about the four year mark, as they aren't as predictable as the ones made years ago- the plates deteriorate from vibration, then one day they just won't start (or take a full charge). The red top is warrantied three years (but if treated well, good for longer than that). -
MacLeod wrote:But then the Duralast Gold looks pretty good as well with 875 CCA and 110 reserve capacity for $65.'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
Sirius Starmate 4 Satellite Radio
Beltronics Vector 995 Radar Detector -
swerve wrote:I... have a red top'98 Honda Accord LX Sedan
Alpine CDA-9847
Alpine MRP-F240
Polk Audio db1000
Polk Audio db650
Polk Audio db690
any 900 or higher CCA battery - standard lead acid battery is fine.The Artist formerly known as PoweredByDodge
