Good deal on a 30 CRT hi def SONY KD30XS955
Schris22
http://www.jr.com/JRProductPage.process?Product_Id=4048191
30" 16:9 CRT Picture Tube / ATSC Integrated Tuner for HDTV capability / CableCARD Slot / Size WHD: 35 3/8 x 23 3/4 x 22 1/4 - 154 Pounds
# You don't need to spend lots of money to enjoy widescreen HDTV capable TV. You also don't have to wonder which technology is better or more reliable. This 30-inch widescreen TV features a Super Fine Pitch CRT, Hi-Scan 1080i( Display, and Cinemotion Reverse 3-2 Pulldown Technology, the KD-30XS955 brings you a visual that is brighter and more vivid than ever before. The KD-30XS955 also features an ATSC Integrated Tuner and is Digital Cable Ready with a CableCard Slot. You can even view your photos onscreen with its built-in Enhanced Memory Stick® Media slot. An ATSC tuner lets you receive widescreen HDTV broadcasts for FREE using an Optional antenna. The CableCARD slot enables quick hookup with your local cableTV carrier's Digital TV service (subscription required). Super Fine Pitch CRT provides better image detail with High Definition sources, improved picture quality, and better edge detail for both moving and still images. No visible vertical lines
# Digital Reality Creation (DRC) Multifunction Unlike conventional line doublers, the DRC Multifunction feature replaces the signals NTSC waveform with the HD equivalent, while doubling the number of vertical and horizontal lines. This results in four times the density for quality sources, such as DVD, satellite and digital camcorders. The Video Menu allows you to select interlaced, progressive or CineMotion output.
# HD Detailer Wide Band Video Amplifier has a high bandwidth frequency rating, allowing it to send more video information to the screen, for finer picture quality.
# HDMI Interface (High-Definition Multimedia Interface) provides an uncompressed, all-digital audio/video interface between the TV and any HDMI-equipped audio/video component, such as a set-top box, DVD player, and A/V receiver. HDMI supports enhanced, or high-definition video, plus multi-channel digital audio
# Inputs and Outputs - Component Video Input (Y/PB/PR): 2 Rear / Composite Input: 1 Front/3 Rear / S-Video Input: (With Detection): 1 Front/2 Rear / Control S: 1 Rear / HDMI: 1 rear
# ATSC - QAM - NTSC TV tuners
# V-Chip parental TV control
# TruSurround SRS Audio (7.5 Watt x 2 With 15W Sub) through internal speakers with Steady Sound Automatic Volume Control With BBE Audio Effect
# Includes Remote Control (supplied with batteries)
# Size (WxHxD):35.8" x 23.8 x 22.3"
I wish i had just a lil more cash
Chris
Chris
Receiver: Onkyo TX-SR502-S
DVD Player: Pioneer DV-578A-S
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
Subwoofer: 10'' Dayton 100 Watt
Left and Right: R50
Center: CS1
Rear Center: R15
Surrounds: R30
