Pioneer DV-588A
okiepolkie
okiepolkie Posts: 2,258
edited January 2006 in Electronics
Anyone use this model? DVD Benchmark thought highly of it. I just wanted some real user experience.
Zach
Tschüss
Zach
Post edited by okiepolkie on
  • Schris22
    Schris22 Posts: 983
    edited January 2006
    I use the 78 version which is the one before it.
    I thought it's a good value dvd player. i don't have the proper display devices to show it off...but I think everything is working out fine for me. It's the cheapest I think you can go for dvd-a and sacd!
    The difference between mine and this new one is divx and some styling...which i dont' care for as well.
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • schwarcw
    schwarcw Posts: 7,358
    edited January 2006
    Hi Zach!
    I bought this player in July. No problems. I listen to SACD and DVD-Audio both in multi channel and two channel. I think it's a great player for the price. I wouldn't hesitate to buy it if this is the price range your looking for.
    Carl
    heiney9 Posts: 25,501
    edited January 2006
    Pioneer has been great for video, I've owned (2) DV-525 and DV-333 (still do). These players are bit older, the DV-333 crapped out very early on in it's life, which a majority did. This was a very big problem for Pioneer. I actually took a step backwards at that point and started using the DV-525 which was the DV-333 predecessor. I've always been impressed with the video quality (although todays players are much better) but the audio quality in every DVD player I've heard blows chunks.
    My Mitsubishi TV is older so doesn't benefit from having a spanking new DVD player. When I upgrade my TV I will do the same with the DVD player (unless this one dies sooner), but I will always run the audio thru an external DAC as there is absolutely no comparison, regardless of format (DVD-A or SACD).
    Bottom line---Pioneer is solid, very solid for video and as I stated all DVD player audio sections leave alot to be desired.
  • okiepolkie
    edited January 2006
    I may pick this one up a little later. I was going to get this for an install I'm working on because my distributor didn't have much of a selection in stock. I ended up getting a refurbed HK from their ebay store. I wanted to match the receiver(HK 135).
    Thanks for all of the help guys.
    Zach
    Tschüss
    Zach
