Sub's Power Cable
fab5valentine
On the LFM-1, the power cable doest seem to go in very far. It's about 1/16" from sitting flush, but there is a a molded plastic peg in there limiting the cable's travel. Is this normal? Doesn't seem in very much.. Also for a large beefy sub the removable cable seems a little whimpy, any suggestions?
-fab5valentine
-fab5valentine
-fab5
Klipsch RB81's/RC62/RS52's
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Toshiba 56MX195 1080p
SVS PB12+/2
Denon 3808CI
Panasonic BD60
Post edited by fab5valentine on
I thought the same thing so I contacted Outlaw and they confirmed that you can upgrade with a higher awg 3 prong cord (which are easier to find than 2 prong). The 3rd prong will not be connected to anything.
A cheap upgrade to a 14 awg cord is the Volex 17604 or 17605.
Adam5.1 and 2.0 ch Basement Media Room: Outlaw 975/Emotiva DC-1/Rotel RB-1582 MKII/Rotel RB-1552/Audiosource Amp 3/Polk LS90, CS400i, FX500i/Outlaw X-12, LFM-1/JVD DLA-HD250/Da-Lite 100" HCCV/Sony ES BDP/Sonos Connect. DC-1/RB-1582 MKII/Sonos Connect also feed Polk 7C in garage or Dayton IO655 on patio.
2.1 ch Basement Gym: Denon AVR-2807/Klipsch Forte I or NHT SB2/JBL SUB 550P x 2/Chromecast Audio.
2.0 ch Living Room: Rotel RX-1052/Emotiva DC-1/Klipsch RF-7 III/Sony ES BDP/LG 65" LED.
2.0 ch Semi-portable: Klipsch Powergate/NHT SB3/Chromecast Audio.
Kitchen: Sonos Play5.
