SDA-1C Crossover question
juddev
How common is the cold solder problem on SDA crossovers?
I have 3 sets of SDA's (1) SDA-2 and (2) SDA 1's and so far I have found cold solder points on 2 of them.
Also does anyone who has replaced the crossover components on a SDA 1 C, have A parts list and the best (also cheapest) place to order from?
SDA 1C Studio
SDA 1 OAK
Sda 2 Walnut
MONITOR 7B
MONITOR 5
SDA 1 OAK
Sda 2 Walnut
MONITOR 7B
MONITOR 5
Post edited by juddev on
Considering the age I'm not surprised you found a bad joint or two. Although, I've not heard of anyone else having that problem.
Do a search, you'll find the info you seek. I will say this, you have quality speakers that can be made even better, so why use cheap parts?Political Correctness'.........defined
President of Club Polk -
I just rebuilt 4 sda 1c x-overs, and I used the Solen Pb's,pm me if you need a parts list,also be sure to replace the polys, polk will send them to you @ no charge if you ask nicely
EDIT; did not notice any cold solder joints in mine.JC approves....he told me so. (F-1 nut) -
George, can you send me a copy of the parts list..
Are the Solen's the best you can buy for replacement ?
If I'm going to redo the xovers then I'd like to get the best ..
Regards,
JoseOriginal SDA owner 1988 - 2006
Tyler Linbrook owner 2006 -
http://home.versatel.nl/geenius/Cap.html
http://ldsg.snippets.org/appdx-ec.php3#CAPS
http://www.10audio.com/sonicraft_vh-oimp.htmPolitical Correctness'.........defined
Pm'd you yesterday with the list,, I used the Solen pb series, I'm pleased with the results, however, it's up to you as to brand. Please pm me again if you need me to re-send info
Edit: Thanks Jesse,for the links that you posted
Thanks for the info guys.
I'll look at the Mundorf ($20ea.) & Solen caps.
Regards,
Mundorf prices vary for each value, like all cap companies prices do. I recommend Sonicaps for their sound and good value for the money.Political Correctness'.........defined
Where do you get Sonicaps ?
Thanks for the info..
Regards,
http://www.soniccraft.com/products.htm
They are at CES and will be closed until Jan. 10th. They also sell many other brands, Jeff will be happy to discuss with you what he thinks would be best for your application.Political Correctness'.........defined
Thanks F1nut ,,
BTW, how do you tell if a cap is bad ?
Regards,
You'll know it when you hear it.Political Correctness'.........defined
