RTi or LSi
fox
fox Posts: 62
edited January 2006 in Speakers
Right now, I have the RTi 70s. While they have served my needs well, I am thinking about upgrading to one of these models. RTi 10, RTi 12, or LSi 15. I almost think the RTi 12s are to large for my allowable space. That and with the price difference not all that much why not go with the LSi 15s. I am running a 225 watt separate amp so driving the LSi's should not be a problem from what I am being told. The one minus might be that I am using a CSi 30 center channel which means no timber match for the fronts should I go with the LSi series. I'm also trying to limit the cost therefore I would rather not also commit to a new center channel. I know everybody has an opinion, I also know that the LSi would be the best sounding speaker and I would like to use these for perhaps the next 20 years, hopefully, they would stand the test of time. For anyone who has used any of these models, any thoughts as to what might make the most sense with respect to cost, sound and all that? Finally, even though I feel the RTi 12s are bigger than I really want for the room that I have, I would still consider them if they may seem to be the better way to go. Thanks to all on this..
Post edited by fox on
  • okiepolkie
    okiepolkie Posts: 2,258
    edited January 2006
    My opinion is to get the LSi15's, then upgrade the center later.
    Here is a thread that may help your decision out a little bit as well: http://www.polkaudio.com/forums/showthread.php?t=34196&highlight=lsi+rti
    Tschüss
    Zach
  • Early B.
    Early B. Posts: 7,900
    edited January 2006
    Yep. Get the Lsi15's and worry about upgrading the center channel later. You'll hear a substantial improvement over the 70's.
    "God grooves with tubes."
  • Schris22
    Schris22 Posts: 983
    edited January 2006
    if you already have the power to run them (something a lot of people spend more $$ when going LSI) then go lsi. Center later like okie said
    Chris
    Receiver: Onkyo TX-SR502-S
    DVD Player: Pioneer DV-578A-S
    Left and Right: R50
    Center: CS1
    Rear Center: R15
    Surrounds: R30
    Subwoofer: 10'' Dayton 100 Watt
  • fox
    fox Posts: 62
    edited January 2006
    Thanks all, like you, I too think that the LSi series would be the best way to go.
    Hopefully later, an LSi center could be picked up.
  • aaharvel
    aaharvel Posts: 4,489
    edited January 2006
    if you're going to upgrade then UPgrade.
    Lsi15, and keep the csi30 until you've heard all 3 of them together.
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2006
    Lsi's all the way . I find them to be great for movies and music. I have an LSI9 as a center though as I did not really like the LSIC center channel.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
  • tdeluce
    tdeluce Posts: 107
    edited January 2006
    What didn't you like about the LSiC center? How is the LSi9 different ( besides cosmetically )?
    Pio Elite 60 in 1080p PRO-150FD KURO
    Integra DTC-9.8 - Pio Elite BDP-95FD
    Cinenova Grande 3 ( 600W x 3 ) - Polk LSi15s, LSiC
    Outlaw M2200s x 2 ( 300W x 2 ) - Polk LC265i x 2
    Velodyne HGS-15X
  • wingnut4772
    edited January 2006
    I found that I had difficulty getting clear dialog from the LSIC and had to run it REALLY hot in relation to my other speakers to hear the movie. I believe that it is the nature of the crossover that is the culprit ( hopefully someone smarter here can explain that). I am not alone though. Here is a thread on the subject and if you do a search you will find others.
    By the way...are you still digging that Cinenova?
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000
    Oppo BDP 95
    Sony PS3
    Squeezebox Touch
