Mmc6500
crdickey
I have just replaced a set of Clarion component speakers with the Polk MMC 6500 and had everything wired by the book and they sounded good. Then about 1/2 hour of playing the music shut off and was replaced by a loud chirping sound. I have another set of Clarions powered off the same amp and they have no sound either but no chirping either. The Amp is a Clarion APX400.4M 200W (50Wx4) and has been faultless for a year. If I had blown the fuse in the Amp I shouldn't hear any chirping.
Crossover is wired to tweeter in / single input / tweeter output to the tweeter and woofer output to the 6.5".
Only thing I'm unsure of is if I switched the pos and neg inputs from the Amp to the crossover.
Ideas?
Ideas?
Post edited by crdickey on
switching the (+) and (-) outputs wouldn't do a thing, unless you only did it on one channel, and even then it would only mess with the imaging, not make a popping sound... if it does it with a known-good pair of speakers, the next suspect is the amp... if you have one available, swap in a known-good amp and see if the sound goes away... if it does, you know that the amp is the culprit, and if the chirp is still there, you know it's the headunit...
naturally, you should first ensure you have good connections on all wires, especially where the ground cable meets the chassis, it should be very tight on bare metal...It's not good, very fundamentally simply not good. - geolemon
Neo is right if you had the outputs crossed it would not hurt a thing. Now it might not sound as good but no chirping noise like your describing. I would say it's the amp causing the problem because all four speakers are not working. I would first check your ground to make sure it's not loose and has a good connection. I have seen grounds cause people a lot of headache's. If it's not the ground i would replace the amp and see if it fixes the problem.
Sounds like a short and most likely in the speaker wire.
Check the connections to the amp first and make sure no strands of one wire are touching the strands of another wire. Then pull out the speaker and check the same thing.polkaudio sound quality competitor since 2005
I would also give a good inspection to the crossovers on the speakers or tweeters if they are there. Look for a blown capacitor (supposed to look like a tiny can, but exploded will see two wires and a mess of fibers) Or a bad solder joint on the speaker.___________________________
Total cost of materials: Going up...
Time spent: Countless Hours...
Cranking the system, having it quiet outside the car, and sound that takes the rear-view off inside: PRICELESS
For some things in life, you pay others to do it... For a masterpeice, do it yourself. -
I'm going to guess head unit. Don't know why, but I am...:D
Hope you get your problem solved!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
