breaking in 465 necessary?
MrPackard
MrPackard Posts: 4
edited May 2002 in Car Audio & Electronics
I have a set of momo 465 components and a set of 6.5 coax speakers. Is it neccesary to play these speakers at low volume for awhile to "break them in"??? I heard something about breaking speakers in somewhere and I was just curious as I am installing them TOMORROW!!! Thanks!
-MrPackard
Post edited by MrPackard on
  • sntnsupermen131
    sntnsupermen131 Posts: 1,831
    edited April 2002
    how long do you need to break them in?
    surely not 40 hours like the subs...
    -cody
  • MrPackard
    MrPackard Posts: 4
    edited April 2002
    My friend that is helping me install my system had a docotors appointment today so we rescheduled for Thursday. I guess that gives me time to ask a few more questions =).
    I had time to take the door panel off today and check out the factory speaker. There is a plastic "cup" that went behing the factory speaker and kind of shielded it from behind. My new speakers don't fit in that "cup" is it important? Do I need to put anything between the speaker and the inside of the door? Also how long do the speakers need to be broken in, and do you get paid by the question Kim? =) Thanks!
    -MrPackard
  • Systems
    Systems Posts: 14,873
    edited May 2002
    and how long do you break them in for?
    Testing
    Testing
    Testing
  • Systems
    edited May 2002
    40 Hours.
    Testing
    Testing
    Testing
