Banana Plug or no Banana Plug
rrgrippi
rrgrippi Posts: 3
Okay, I have read mixed reviews...advantages and disadvantages. Any thoughts on whether to use a banana plug or bare wire connections? I have a Yamaha RXV1400, T90eEURO, PSW10, CSi3, and Mirage rears.
Post edited by rrgrippi on
  • michael_w
    michael_w Posts: 2,813
    edited December 2005
    The only advantage to bananas are for convience and asthetics (also to save your wire from being cut every few times you have to take it in or out of the bindings posts. They're just simply handy. I don't notice a difference with or without them in terms of sound quality, but I do find they damn handy when I want to change out my speakers to try something new.
  • dorokusai
    dorokusai Posts: 25,576
    I agree, they are simply convenient. I could care less if they aren't the ideal connection method.
  • PolkThug
    PolkThug Posts: 7,532
    They make everything look purty.
  • Tour2ma
    Tour2ma Posts: 10,177
    Yup bananas are handy, but can also be borderline essential as tight as the backside of AV amps are packed, e.g., Sunfire Cinema Grands. I favor dual bananas.
    But if you do not need them, I favor bare wire. Why introduce unnesessary connections, if you do not need to?
    As for trimming.. if you go with bare ends, you may have to do so annually anyway due to oxidation. Tinning the ends with solder can reduce the need to do this, as the solder oxidizes far slower than copper.
    Welcome to the forum...
    More later,
    Tour...
    Vox Copuli
  • WilliamM2
    WilliamM2 Posts: 4,808
    I use both. Banana's for the amp connection, and bare wire at the speaker connection.
    I like to remove all my components from the rack to clean/dust them every few months, the banana's make this easier. I use bare wire at the speaker terminals because I rarely ever remove them.
  • michael_w
    Tinning also works quite well but I find that the wire still needs to be trimmed back once in a while because it just gets too contorted and smooshed. If you want a solid connection while sacrificing a little convience you can try spades. They offer the clean look and add to the ease of connecting things, but not quite as easy as bananas.
  • Willow
    Willow Posts: 11,296
    I use them and like them. As mentioned it makes it easier when playing around the backside.
  • Eric W
    Eric W Posts: 556
    Bananas are great for convenience. If you have a tendency to move your system around or do alot of connect/disconnecting then bananas are wonderful. However they do tend to loose their friction after repeated connecting/disconnecting, and they also add two more connection points (from wire to plug, from plug to binding post). I do like using them on the back of multichannel receivers where it can be almost impossible to get a bare wire within the terminals without strands sticking out or a short being created.
    -Eric
    -Polk Audio
  • steveinaz
    steveinaz Posts: 19,546
    Agree, I could never understand the argument that spades are better, bananas have far more surface area contact then spades, IMO.
  • Tour2ma
    Eric Wong wrote:
    ...and they also add two more connection points (from wire to plug, from plug to binding post).
    Only versus not connecting the wire... :D... if you connect the wire, it's one more.
    More later,
    Tour...
    Vox Copuli
  • aaharvel
    aaharvel Posts: 4,489
    nanners rock
    H/K Signature 2.1+235
    Jungson MagicBoat II
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
    "People working at Polk Audio must sit around the office and just laugh their balls off reading many of these comments." -Lush
  • doggie750
    doggie750 Posts: 1,160
    This make me believe that Soldered bare wire is better than with terminators.....Please confirm?????????
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • shack
    shack Posts: 11,154
    "Yes! We have no bananas..."
    Well actually, bananas are all that I use...except for my older speakers/gear that don't have 5 way binding posts...then it's bare wire all the way. The advantage of banana plugs far outwiegh any sonic improvement from bare wire.
  • Tour2ma
    ^ Well that didn't confirm anything... :p
    More later,
    Tour...
    Vox Copuli
  • aaharvel
    just bought 20 m.cable nanners off of ebay for the back of my 2Adcoms. $30 not too bad.
    Revel Performa M-20
    Velodyne cht-10 sub
    Rega P1 Turntable
  • shack
    shack Posts: 11,154
    We ARE talking about bananas here....what did you expect....War and Peace?
  • MLZ
    MLZ Posts: 214
    This is probably a very simple question, but I keep reading about a "Five Way Binding Post" for connecting speakers, etc., but what are the "5 Ways"?
    1: Speaker wire through hole at base of post and tighten nut
    2: Banana Plug
    3: Spade at base and tighten nut?
    4: ?
    5: ?
  • shack
    shack Posts: 11,154
    1) bare-wire
    2) spade conections
    3) banana terminations
    4) pins
    5) nothing
  • Dennis Gardner
    Dennis Gardner Posts: 4,861
    Locking bananas rule! Best of both worlds.
  • BIZILL
    BIZILL Posts: 5,432
    i'm thinking i should've spent double and went ahead and gotten the locking bananas.
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    7.1 SURROUNDS: RTI6'S
    XBOX 360
    WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
    http://polkarmy.com/forums/index.php
    bobman1235 wrote:
    I have no facts to back that up, but I never let facts get in the way of my arguments.
  • michael_w
    I think the fifth way would be those flexi pin things... more used for the spring clips found on lower quality componnents.
  • Dennis Gardner
    I switch between tube/SS amps on my SDAs often enough that I was loosening the springs on my dual bananas so I tried the expanding center post style and love them.
  • BIZILL
    BIZILL Posts: 5,432
    2: Banana Plug
    4: ?
    5: ?
    4: pins
    5: bare wire looped around post and tightened instead of through the hole?
    ONKYO TX-SR805
    CENTER: CSI5
    MAINS: RTI8'S
    SURROUNDS: RTI8'S
    XBOX 360
  • dorokusai
    Look Up....
    F1nut Posts: 52,101
    I love sticking my banana in tight holes. :D
    These discussions about which termination style is best are pointless. I've yet to hear a difference myself or heard of anybody that could tell a difference.
  • michael_w
    Exactly why I choose banana's. They're convient and I can't tell the difference.
  • george daniel
    george daniel Posts: 12,096
    I prefer the Chaquita Banana :)
  • steveinaz
    My next set of wires will be banana all around, my set now is spade/spade, it's a pain in the ****.
  • TheReaper
    TheReaper Posts: 636
    dorokusai wrote:
    Look Up....
    http://www.audioc.com/library1/connect.htm
    1) Barewire
    Least expensive, virtually no contact resistance when new, easy to do. Frayed wires can cause electrical shorts. Bare wire oxidizes causing excessive contact resistance if not cleaned frequently.
    2) Tinned Barewire
    Just requires the addition of solder. Correctly soldered ends won't fray. Wire won't oxidize, very inexpensive and easy. Can corrode over time causing excessive resistance.
    3) Spade Lugs
    Quick hookup and disconnect from 5-way binding posts. Solid electrical contact. Won't oxidize or corrode if gold-plated. Clean look. For the least oxidation, the spade connector and the binding post it is used with should be the same metal, preferably gold plated.
    4) Banana Plugs
    Very fast hookup and disconnect from 5-way binding posts. Good electrical contact IF the plug has strong springs. Clean look. Some bananas have only three or four springs, and those springs may not maintain enough tension to minimize contact resistance. The gold-plated bananas with 9 springs are usually of high-quality.
    5) Pin Connectors
    Neat, quick connection with either spring loaded terminals or 5-way posts. More contact resistance than spades/bananas/ bare wires because of less contact area.
    Note: Crutchfield's advisor has dual-banana plugs as 1 of the five, instead of tinned wire.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
  • doggie750
    GOLD plated............Is good what about the metal underneath the Gold????.........
    They vary from Ni, Silver, Cu............I believe it doesn't matter as long you have a plated metal with GOLD. Please confirm.............
    Just to remind you POLKs..........Go to Circuit CIty and SACD cables (6 IC400) are on clearance for $35 ONLY.........not offered online.........
    Godspeed,
    D0661E
    Surrounds: RTis
    Sub:SVS PB12-Plus/2
