is this a good setup???
Systems
well right now i have
alpine cda7863 head unit
polk mm465's up front
polk 5.25 db's in rear
subs are 2 mm110's
should my amps be bigger?????
i currently have alpine t757 for subs
and alpine f407 for rest.. the 407 dosent seem to be enought for my mids and tweets
i have the f407 bridged on the mm465's and is that enough
i also plan on getting the new alpine cda 7977 with 4v outs
would that bump me up more
any suggest,,,,,,, and i can buy a diff. amp if you fill nessasary
but def want to stick with alpine
thanks jaron
subs are 2 mm110's
thanks jaron
Testing
Testing
Testing
Testing
Testing
Jaron,
Try bridging the amplifier and connect the MM465's to the amp.
In the bridged mode this amp has a power rating of 320 Watts
per channel. Set the high pass crossover to 80 Hertz and do the same for the low pass filter. Because the amplifiers use a 12 dB per octave slope, you may have to invert the phase on either the subs, or the component speakers and back speakers to get the system in phase acoustically at your listening position inside the vehicle.
If you have any questions feel free to give us a call
at 800-377-7655 between the hoursof 9 AM to 6 PM Eastern time and we will be glad to help.
Thanks,
Kim, Polk AudioTesting
Testing
Testing
