Need a good CD/DVD scratch remover...
MSkeezer
I've got a few DVD's that are pretty scratched up. Do any of these so called scratch removers work? Are there any drawbacks to using them? Any picture/sound loss? Thanks.
Post edited by MSkeezer on
here is one I found I was thinking of getting.
http://www.amazon.com/gp/product/B0002A9SJ2/ref=pd_sxp_elt_l1/103-6771245-7895848?n=172282
There is some on ebay from simotech but cannot find any reviews.Matthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
Thanks man. I'll definitely be picking this up.
Use a decent synthetic car wax scratch remover. Mequires Scratch remover for example. Follow the directions on the bottle.
I have managed to get non playing cd's to play with mothers aluminium pollish.Skynut
SOPA® Founder
The system Almost there
DVD Onkyo DV-SP802
Sunfire Theater Grand II
Sherbourn 7/2100
Panamax 5510 power conditioner (for electronics)
2 PSAudio UPC-200 power conditioners (for amps)
Front L/R RT3000p (Bi-Wired)
Center CS1000p (Bi-Wired) (under the television)
Center RT2000p's (Bi-Wired) (on each side of the television)
Sur FX1000
SVS ultra plus 2
www.ShadetreesMachineShop.com
Thanks for looking -
Thanks for the suggestions.
waymond wrote:Use a decent synthetic car wax scratch remover. Mequires Scratch remover for example. Follow the directions on the bottle.
I agree. I have had really good luck with Meguiar's Scratch X. You should be able to get it at any Target, Wal-Mart, or auto parts store for about $8. It's the only thing I have used that doesn't leave really fine swirl marks in the disc. Plus one tube will clean a ton of discs.
Oh yea....works good on cars too.
HT
Mits WD-65737, DirecTV, Oppo DV-970HD, XBOX ONE, Yamaha RX-A1030, Parasound Halo A23, Rotel RB-985, Music Hall MMF-7, Parasound PPH-100, LSi-15, LSi-C, LSi-FX, LSi-7, PSW-1000, Monster HTS2600
2 CH
Parasound Halo P3, Parasound Halo A21, Sutherland Ph.D, VPI Classic 3 w/ 3D arm & Soundsmith Aida Cartridge, Arcam CD72T, B&W 802 S3, Monster HTS2500, -
Some interesting ideas in this thread I never would have thought of...
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
Pioneer Premier DEH-P860MP, Memphis 16-MCA3004, Boston Acoustic RC520 -
Hmmm. The Scratch X stuff looks interesting. And it's pretty cheap. I think I'll try that out before I invest $30 in a dedicated scratch remover.
Great ideas guys. Thanks.Michael
NORTH of 60° -
This may seem obvious to most of you, but I am clueless..SORRY! I have Meguires in my garage. How do I apply it to fix the scratches? In a circular pattern around the disk, or in straight lines out from the center of the disk, or does it not matter?
I just bought my son the movie CARS and its so watched that the dvd is already scratched and he gets upset that it constantly resets back to the begining halfway thru the movie. :mad: I'd give anything to get this fixed asap! Thanks so much for the help, you guys rock for giving me this idea! -
Would you give, say, $15 for a new copy of CARs?pillotopp wrote:This may seem obvious to most of you, but I am clueless..SORRY! I have Meguires in my garage. How do I apply it to fix the scratches? In a circular pattern around the disk, or in straight lines out from the center of the disk, or does it not matter?
I'm an ****, I know... -
I buy lots of used CDs. Many are labeled as "scratched" or "very scratched" and sell for anywhere between $.18 and $1.95. Some of them look like they were cleaned with a piece of sandpaper. I have yet to have one not play or even skip because of the scratches and I have never done anything to "repair" them. We also rent a lot of DVDs that are poorly maintained. If they don't play it is not due to scratches but smudges or worse on the disc. Most good CDPs or DVD players have excellent error correction capabilities and there is enough error correction code (ECC) added to the discs for scratches to have no effect on playback. A problem may occur if the data is more compressed or if the scratch happens to cover an entire ECC block."Just because youre offended doesnt mean youre right." - Ricky Gervais
"Consistency requires you to be as ignorant today as you were a year ago." - Bernard Berenson -
You apply and wipe the scratch remover against the grain (straight lines from the center). Scratches running in the direction of the track are most likely to cause uncorrectable errors. By trying to remove "fill" scratches in this direction you might be doing more harm then good.
Never clean a DVD or CD in a circular motion. -
Thanks so much for the instruction on how to apply the product!
I PRE ORDERED the stupid cars movie on line figuring I'd get it earlier than the general public...I still didn't get it until it was available in stores so I preordered and paid shipping for nothing...(as we say in New England) wicked REE-TAH-DID??!!!
But it came in a fancy package different than the store has. BIG DEAl.
So in answer to your question NO I do not want to spend 15 bucks for ANOTHER one when I haven't even had this one for 2 months yet! Not unless the dvd is ruined for good by the scratch I have.
I have also plenty of scratches on other dvd's and they still play...The Cars movie has a few light scratches but it has one that looks deep and every time the dvd gets to a certain point in the movie it just resets and starts all over again. I cant even fast forward past that part a few frames, the dvd player will not budge! That happens in 2 different places on the disk caused I assume by the same scratch.
I will go get my scratch remover and see if I can fix the thing. If I can't then I can rent a copy for 1 dollar at Blockbuster and my brother can burn it for me on his computer:o ..Illegal I know but I refuse to keep buying the same movie over and over because my 3 year old can't keep his hands off of them! -
If I am not mistaken. A player will read the disc from the inside outward. This might help in locating the scratch causing the prob.:eek: From the bottom it looks like a steep incline, From the top another down hill slope of mine.:mad: But I know the equilibrium's there!:cool: .."Faith No More"
Sony cx985v (for now)
BBE 482i
B&K AVP 1030
Adcom GFA 555 mk 2
AudioQuest Crystal 2 spk wire
Nordost RCA
SDA 3.1 tl RD0 tweets
Belkin pf60
Carver TFM 55x
Signal Analog 2 RCA
AudioQuestType 4
VMPS Original Tall Boy (Mega Woofers soon) -
Try this link Mapleshade has a great reputation for these products although I haven't tried the CD treatments yet I have ordered them and received them.
Joe -
Brasso on a q-tip. rub in lines from the center straight out to the edge (perpendicular to the way you use a vinyl brush).Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i
