Wall mount LSI7 ?? Drywall ok?
Anyone wall mount the LSI-7 without using a stud behind the drywall? Any suggestions on mounting hardware? Parts Express seems to have a good selection. http://www.partsexpress.com/webpage.cfm?webpage_id=3&SO=2&&DID=7&CATID=49&ObjectGroup_ID=372
Front: LSI7
Center: LSIC
Surrounds: LSI7
SVS PB2-ISD SUB [MONOLITH!]
ATI 1805 Amp
Center: LSIC
Surrounds: LSI7
ATI 1805 Amp
Post edited by wrxmy02 on
I wall mounted my RT35i on the wall with just a dry wall anchor and a bolt..- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Get a B-Tech wall mount (bt-77). they have 4 screws per mount to hold it to the wall. With standard drywall anchors (4 of em) I bet it will hold your 7's untill the wall comes down around it.
(I purchased mine at Crutchfield and am using it on my LSi7's)
