Csi5 vs CS2 for center channel
BjornB17
BjornB17 Posts: 752
edited July 2008 in Speakers
I have polk monitor 70s for the front left and front right, and currently a CS2. I was wondering if a Csi5 would still be a good match considering it's from a different product line. Thanks!
KEF Q150 | Rythmik F12 | Yamaha Aventage RX-A780
Post edited by BjornB17 on
  • tearsinraine
    tearsinraine Posts: 5
    edited December 2006
    I actually have a similar question as BjornB17.
    I'm looking into picking up a center for my Monitor 70s and the CS2 is listed as a match. But the CSi5's are getting lots of good reviews here so they seem tempting as an interim upgrade path (although realistically, I won't be upgrading my mains anytime soon)
    Anyone have any opinions?
    Should I just go with the CS2? Or would the CSi5 still match?
  • Schwingding
    Schwingding Posts: 363
    I've had both. When I went to the RTi series towers all around, I matched them with the CSi5.
    The CSi5 is a "brighter" speaker overall. It does more closely match the tones of the RTi line compared to the Monitor 70 - which I also had, btw.
    Voice reproduction is definitely more lifelike with the CSi25. The first time I used mine I was actually startled by the clarity and realism.
    Given my experience with all of the things you are considering, were I to do it over again and stick with the Monitor 70s, I think I would stick with the CS2.
    HT/music rig
    Panasonic PX60U 50" plasma
    Yamaha 5990 AVR
    Onix SP3 tube amp
    bunch of Outlaw 2200 monoblocks
    DUAL SVS PB12+/2 subs :eek:
    Denon 3910 DVD/SACD/DVD-A
    DirecTV HR10-250 DVR
    Onix Strata Mini mains
    Mirage OM10 surrounds
    Polk CSi5 center
    Polk SC80 rear surrounds
    Samsung BDP1000 blu-ray player
    Bedroom rig
    Jolida SJ302a tube amp
    Denon 2910 universal player
    Onix Ref 1 monitors
    Velodyne minivee
  • Refefer
    Refefer Posts: 1,280
    I'm not familiar with the driver selection difference for either of them, but if they don't happen to be the same(and I don't think they are), I would stick with the CS2 if you're not planning on upgrading the system in the near future. The big reason for this would be that the timber would be slightly off and cause your system to sound less realistic.
    If you happen to know the driver compliment is the same, by all means purchase the upgrade. The sound difference was the only reason I could think of.
    Maybe someone more familiar with those two centers will comment soon.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
  • amulford
    amulford Posts: 5,020
    If you have matching timbre for your front stage, that is your front mains and center channel are from the same line, stay with that. What will happen is when the soundtrack pans across the front, you will hear the difference in the speakers, and that probably is not what you want. If you stay with the same line, the transition will be seemless, which IS what you want.
    Is the CSi5 a better center speaker? Yes, it is. But like Refefer said, unless you plan on upgrading you front mains, you should stick with the one you have.
  • zombie boy 2000
    zombie boy 2000 Posts: 6,641
    Really good advise thus far...
    Welcome to the Forum Tears!
  • tommyboy
    tommyboy Posts: 1,414
    When you look at my sig, you'll notice I have three different lines of polk speakers:eek: . When I went from Onkyo HTIB to the monitor 50s, I already had the r15s but with choosing a center channel, I was thinking of the either the CSi 3 or the CS1. The center channel to me is the most important speaker for HT, and when I heard the CS1 at CC, to tell you the truth, I was disappointed... So I said WTH, I might as well get the csi3. The csi3 IMO can reproduce voices much clearer than the cs1. Well, after having my system for almost a year now, I can tell you that (to my ears and my buddies) there is almost no difference in sound between the center and the monitor 50s. The R15s however are the "odd man out", but I don't want to spend anymore money on my system right now until I make the big upgrade in a year or two...
    with your issue though, I think I would still stick with the cs2. IMO The cs2 is a much better center then the cs1 just because its physically bigger and is able to handle the voices and louder volumes... But if the difference between the M50s and CSi3 is the same as the M70s and CSi5s.... well, you know what to do next...
    My biggest advise is to just go listen yourself...
    Tommyboy
    AVR: H/K AVR240
    Fronts: Monitor 50s
    Center: CSI3
    surrounds: R15s
    Sub:Velodyne DPS10
    Dvd/Cd: Samsung HD upconverter (for now)
    TV: 50" Sammy Plasma
    game hardware: 360 and gcn.
    Gamertag: kovster27
  • NCNog
    NCNog Posts: 11
    I have a CS1 and I am on the fence as well about upgrading. I have 2 Monitor 30's in the front and 2 RM101's in the back. After upgrading my receiver to the Yamaha RX-V2500, I now feel like my center voices have lost a lot of their richness. What I can't determine is if this is a setup issue or a speaker issue.
  • zombie boy 2000
    I believe the CS1 is a better match for the Monitor 30's, so it may very well be a speaker issue.
    (If by "speaker issue", you mean you are unhappy with the general performance of all your speakers.)
  • AndyGwis
    AndyGwis Posts: 3,655
    I had the CSi3 for a while in my Monitor 60/30 setup. Liked it, especially when I had a separate amp running it, but it might be a little too bright for the monitor series. Bright, in this case, also means more clear/crisp, but it did stand out a little.
    I ended up getting the CS2. Not necessarily a better speaker, even given the larger MSRP and size, but it's probably the better fit with your speakers.
    I don't think you'd gain much by going from the CS2 to the CSi5, other than you'd want to upgrade the rest of your speakers to go along with the CSi5.
    Stereo Rig: Hales Revelation 3, Musical Fidelity CD-Pre 24, Forte Model 3 amp, Lexicon RT-10 SACD, MMF-5 w/speedbox, Forte Model 2 Phono Pre, Cardas Crosslink, APC H15, URC MX-950, Lovan Stand
    Bedroom: Samsung HPR-4252, Toshiba HD-A2, HK 3480, Signal Cable, AQ speaker cable, Totem Dreamcatchers, SVS PB10-NSD, URC MX-850
  • tearsinraine
    You guys are awesome! Thanks everyone for all the responses and advice. Looks like I'll be heading out soon for the CS2. :)
    Thanks also for the welcome, Zombie.
  • Humanoid
    Humanoid Posts: 27
    edited January 2007
    Did you ever get your CS2? I just picked up CSi5 to replace my 6 month old CS2. The CSi5 was just a better match for the RTi8's.
    TV: Sony KDSR60XBR2
    AVR: Marantz SR7002
    Mains: Polk RTi8
    CTR: Polk CSi5
    SS: FXi3
    Sub: SVS PB10-NSD
    HD DVD: Toshiba HD-XA2
    BR DVD: Samsung 1400
  • tearsinraine
    edited January 2007
    I did end up getting the CS2... and Monitor 40s for surrounds... and a new receiver (Yamaha RX-V2500)... grrrrr... so much for staying realistic... all I wanted was a center! lol :) I'm pretty happy with the set so far.
    I did LOVE the sound of the CSi5, but I thought the CS2 matched better with my Monitor 70s. I also had no idea how I would place such a beast, even if I would have gotten it. How do you guys do it?
  • cdn5003
    cdn5003 Posts: 144
    edited July 2008
    Humanoid if you still have that CS2 let me know cause i'm looking for one.
    HT Setup: Onkyo 706; Rotel RB-1075; Rti A3; Csi A6; Fxi3's
    2 CH: Squeezebox Touch; Dared SL-2000a; GoldenEar Triton 5 or Lsi9's; Parasound 2125; SVS SB12-NSD; Music Hall DAC 25.2
  • Kchill
    Kchill Posts: 262
    edited July 2008
    Wow this post was pulled from the dead!
    Retired Onkyo 520 (returned broken HK 247)
    Now a Pioneer 1018
    CSi3
    2- RTI10's
    2- R50's
    2- Fxi3's
    Onkyo 250W Sub
    Polk psw-10
    "Inch by inch lifes a cinch, yard by yard life is hard"
  • BjornB17
    BjornB17 Posts: 752
    edited July 2008
    wow I havent been here in like 2+ years and i was surprised to see my post on the first page still!
