Bose 3 - for 5.1 Channel.
Neeraj
Neeraj Posts: 6
edited December 2005 in 2 Channel Audio
Hello Friends,
I have Bose Acoustimass 3 Series IV Black but YAMAHA - HTR-5830 Receiver , a 5.1 channel Amplifier, Can any one among you tell me if I want to make my system 5.1 Channel what do i need to do ?
Request you to let me know at the earliest as I wanna do that quickly.
Thanks in Adavnce :confused:
Take Care
Neeraj.
Post edited by Neeraj on
  • dragon1952
    dragon1952 Posts: 4,907
    welcome to the forum ;)
  • Tour2ma
    Tour2ma Posts: 10,177
    Easy there fellow dragon....
    Neeraj,
    In the future, please look for the appropriate area of the forum for your threads. Your Home Theater question does not fit in the "2 Channel Audio" section.
    You need additional speakers. At least two...
    More later,
    Tour...
    Vox Copuli
  • dragon1952
    Hi Neeraj,
    If I were you and wanted to stick with the Bose I'd look on ebay maybe and try to find another pair of cubes for the rear. It would be hard to match a different manufacturers speakers to your system. Otherwise I'd think about selling the Bose and get something else that matched all around. I guess it depends on what your budget for speakers is like.
    Good luck!
    Rob
  • dragon1952
    Does anyone know how Neeraj can connect the Bose cubes to the Yamaha considering the cubes connect to the sub? I know I've seen this discussed before. :confused:
  • 2+2
    2+2 Posts: 546
    Get a set of RTi floor standers, and a center for your fronts, and use your Bose cubes for surround duty ..
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • Neeraj
    Neeraj Posts: 6
    2+2 reply seems to be too informative.
    However I am not able to deduce anything out of that..May be, it seems I am little inexperienced.
    Thanks anyway 2+2 :)
  • PolkThug
    PolkThug Posts: 7,532
    Go this route: http://www.onecall.com/ProductDetails.aspx?sHist=12-293&menu=true&id=28580
    When you add it to your cart, you'll get a discount and include free FedEx. You'll be amazed at the sonic improvement.
    Regards
